#508203 - 12/01/07 09:46 PM Polishing New Stealth !!
I bought a new Weiand Stealth to go along with my re-build plans over the winter,turns out they dont have a polished version for the rectangular port BBC heads,so I am doing it myself.Heres some pics so far.
This is after about 4-5 hours,big difference I think.
I really like the look of polished aluminum.
I was thinking that after I am all done that it might look nice to do the Weiand & Stealth in bright red,or glossy black.
#508204 - 12/01/07 09:53 PM Re: Polishing New Stealth !! [Re: GuysMonteSS]
Big3 Offline
Big3  Offline
Lancaster, Ohio
nice progress in that time
are those water outlets NOT tapped?
87 MCSS Black w/Saddle
383 w/dart heads,Functional Goodmark hood.
700r-4, Gforce member,4.10s
1LE's w/Hotchkis uppers,2" drop & ZQ8's
#508213 - 12/01/07 10:30 PM Re: Polishing New Stealth !! [Re: Big3]
rons87mcss Offline
rons87mcss  Offline
PA
What does everybody use to polish ther aluminum stuff? I like to hear about stuff that may be around your house if possible. That intake is looking good. It's funny sometimes by the time you put it back on and all the bolt-ons you can't see alot of it. Find them areas and focus elsewhere-LOL!
#508221 - 12/01/07 10:37 PM Re: Polishing New Stealth !! [Re: rons87mcss]
What are you using to sand it with?
#508222 - 12/01/07 10:38 PM Re: Polishing New Stealth !! [Re: rons87mcss]
delmontess Offline
delmontess  Offline
woonsocket r.i.
mothers
monte ss goodwrench,350,world class,T-5,gn 342 posi,line lock, 3" drop in front 4" drop out back tpi is GONE back to the edelbrock
http://tonys57chevy.proboards.com/index.cgi
#508224 - 12/01/07 10:41 PM Re: Polishing New Stealth !! [Re: rons87mcss]
One outlet is tapped,that is the bypass,I think the 2 heater hoses go to the water pump.
I have been using my MotoMaster Demel type tool & accesories,and hand sanding with 50,80,& medium emery paper,got a ways to go yet.I also use aluminum polish on a piece of green Scotch Brite pad,work it in good,then wipe clean.
#508231 - 12/01/07 11:01 PM Re: Polishing New Stealth !! [Re: GuysMonteSS]
rons87mcss Offline
rons87mcss  Offline
PA
Here's what I've done in about an hour with primitive tatics I'm sure, but actually I think it looks ok for a drill and $.88 box of steelwool(I'm still on my first pad!), just need to have the dents removed from the runners
BTW, I just noticed that a deepfreezer must be a popular workbench!
#508263 - 12/02/07 12:43 AM Re: Polishing New Stealth !! [Re: rons87mcss]
Tunedss86 Online content
Tunedss86  Online Content
Eastern Virginia
#508294 - 12/02/07 02:10 AM Re: Polishing New Stealth !! [Re: Tunedss86]
Wow, that thing is sweet. Way to much chrome for me though. I hate polishing.
#508474 - 12/02/07 03:36 PM Re: Polishing New Stealth !! [Re: 406monte]
mymonte-ss Offline
mymonte-ss  Offline
Salisbury NC
From experience, to save you a lot of time start out with something like 180-220 grit sand paper, get the area smooth then start with finer and finer grit paper, or if you have a right angle air grinder use the Roloc disc's to knock everything down, it works a lot faster than just using the steel wool from the begining atleast untill everything gets to the point of getting the high shine out of it.
87 Monte,TPI conversion eng/trans from an 89 IROC had a paxton on it, its for sale! LS1 brakes and 9" rear finished, 3.56 with a locker to be tested. Been sitting since I graduated in 04 on the verge of resurrection. http://www.cardomain.com/ride/3192829
500/thumbs/139739306_2844857802459164_7739908298560387923_o.jpg
by CM1SCW
500/thumbs/562170_385523434820569_1750687250_n1.jpg
by BigReese84
500/thumbs/17Monte79999.JPG
by MikePEI
500/thumbs/84MCSS3.jpg
by 350MCSS
