#342 - 01/12/06 11:42 PM
TPI Help please
GearedSS
stratford,ontario. canada
Started to mess with the car today, and it just didn't want to start. Only been sittin since 1st of Dec. It would start then stall right away. Took about ten min to start with throttle held half open. Finally. Now its running so rich I had to leave garage. Any ideas what me problem might be, or how to fix it? Thanx Jason
#343 - 01/12/06 11:50 PM
Re: TPI Help please
WannaMonte
Grand Rapids, Mi
try asking the guys on thirdgen.org
1985 Monte SS *SOLD* 1991 Camaro Z28 357 SBC, Dart 200cc Iron Eagle Platinums, Lunati Voodoo 268, Holley Stealth Ram, 52mm Throttle Body, 3.5" exhaust -Zoom Zoom
#344 - 01/12/06 11:53 PM
Re: TPI Help please
PontiCarlo468
Arcadia, Florida
Sounds liek its running real rich and holding the throttle half open to get enough air to make the fuel burn correctly... It could be a fuel pressure regulator causing the injectors to "bleed" fuel constantly... It could also be the Oxygen Sensor... I'm just giving suggestions, I'm not that informative about TPI engines... HTH
1987 Monte Carlo SS- Off The Road For Restoration... Then Street/Strip action when done!!! 1987 Chevy Caprice Wagon- New Daily Driver. Olds 307/TH-2004R/2.73s Sargent Of Arms Of Maniacs Minions. Glen502@hotmail.com
#345 - 01/14/06 04:15 AM
Re: TPI Help please
baaboo
Racine, WI
I'd also leans towards excess fuel pressure. Maybe a plugged return line? Throw a gauge on it and see what it reads.
#347 - 01/14/06 04:28 PM
Re: TPI Help please
baaboo
Racine, WI
What do you mean the sending unit? If you can, connect a mechanical gauge right at the fuel rail, to see what the injectors are seeing. What about tyhe pump intake line, is that clear too?
#351 - 01/15/06 01:11 AM
Re: TPI Help please
mybuick
mount prospect, il
find the fuel line return where there is ruber hose on it and pinch the line, then turn on the ign but do not start the car see if the pressure still drops... this will rule out the pump or the sending unit. then if it still drops pull the fuel rail enough to see the injectors and redo the test to see if the injectors are leaking. if not its the regulator.
84 gn with 87 engine .030 109 ballanced, gt51 25#, msd 50# inj, all billet mains, bms rods, ported heads, comp cams .459 lift, champion intake, precision fm, accufb 70mm tb, 340 fp hotwired, northern alum rad, b&m tranny cooler. all on 93 octane...
#353 - 01/15/06 11:28 PM
Re: TPI Help please
mybuick
mount prospect, il
1. you would smell gas from the tail pipes. 2. maby slight chance with the regulator.
#360 - 01/17/06 09:46 PM
Re: TPI Help please
Gruvin
Moderator 15+ Year
Moderator 15+ Year
Texas
Originally posted by Jmans84SS: So I un hook the fuel line feed, and hook it up to the gauge, turn on ignition without starting car, and see if I have steady pressure? yep, unhook the feed from the pump, cap the line with the gauge and check the pressure and watch for bleed off... Hold the pressure a few minutes just to make sure. Re-install the feed line and repeat the process by capping the return line so there is no way for the pressure to release except by the injectors or the regulators(which regulator will not show up on this test due to the circut being capped after the regulator...) Tests should show: test #1 = pump issue, Test #2 = injector/fuel rail issue, nothing on either test = regulator issue(best guess scenario)
My first SS! Sold Jan 2004 ![[Linked Image]](http://www.MonteCarloSS.com/images/Gruvin_84SS_sig.jpg) 87 SS bought 9-5-04: Sold 6-18-2010 - project 87 finds a new home with another undisclosed MonteCarloSS.com member!
#362 - 01/20/06 03:01 AM
Re: TPI Help please
85SSMan
Wichita, Kansas
When I first got my TPI swap complete my car did the same thing. it wound up being that the TPS needed to be reset. Before you pulling your fuel system apart make sure that you have all your sensors and timing set right. Here's how...
#1) Use a jumper and jump the A and B terminals on the ALDL box. #2) Turn the ingnition on, wait 30 seconds and then unplug the IAC (Idle Air Control). Pull jumper wire out. #3) Now using a Volt meter set the TPS (Throtlle Position Sensor) to .54 volts, do this be back probing the sensor with you volt meter and or using some type of scan tool that shows you the TPS voltage. You should be set at .54 volts and closed throtlle and should stedily increase up to around 4.00 volt at wide open throtlle. #4) With a timing light, set your timing, I think it is around 8* BTC, you can set it by ear, just stop adjusting when the idle smoothes out. #5) Block your wheels and set your parking brake. #6) Start the car and put it in Drive, use the idle adjustment screw on the Throttle body to adjust idle to a smooth idle, if your engine is stock your should be between 500-750rpm. #7) Shut car off, you may have to readjust your TPS now (ignition must be on) if you made any adjustment with the Idle adjustment screw. #8) Again make sure ignition is off, plug in IAC, unhook negative battery cable for 30 seconds then reattach. #9) Start car drive normally for 15 minutes with 1-2 second gear passes.
If all checks out here, and you do wind up replacing fuel system parts to get her running agian. This is a good quick way to get the sensors back into spec and your TPI working right.
Good Luck Chris
 1985 Monte SS, Rebuilt L69 with TPI. 200-4R Tranny. 951 Modine with TPI duel fans. True 2 1/4 Flowmaster Duals. B.F.H. made dual hump crossmember. Stock Suspension, interior, and body. SOLD TO INTMDATR3 ON 03/04/06
#366 - 01/22/06 03:07 PM
Re: TPI Help please
JP86SS
Strongsville, Ohio
There are two of them. There is an Intake air temp either under the rear of the plenum or in the line to the MAF (depending if it is SD or MAF setup) The coolant temp "should" be at the front of the intake manifold. There is also the possibility you have fouled the plugs at this point. A cylinder not firing will indicate lean to the o2 sensor and cause extra fuel to be added. that will make the problem worse. Make a datalogging cable (or buy one for $30)and get familiar with using it. The data output will help you see what is working and if all sensors are reading correctly.Reset the TPS and IAC per the instructions above and check that ignition (and plugs) are in good shape. Then go after the problem. What ECM/Setup areyou running?
http://s124.photobucket.com/user/JP86SS/media/Industrial_Park.mp4.html (Movie of old 350 build) PFI, 406, 2400 stall LU, Built 700R4, T-Tops,DIY-PROM, Moates G3, APU1, S_AUJP V4+,NVSRAM Modified Sportsman II's,Stealth Ram polished,BBK 52mm TB,30# SVO's, Pypes 3" dual w/X, WB O2(LC-1), UMI reloc LCA's,Eddy Adj UCA,DS loops, M/T 255 DRs.
by Ritttzz
by Savage 88
by Rebel87SS
by bug
by Aeroaddict
