#468799 - 08/09/07 03:34 PM fi fuel tank sending unit
steve 1961 Offline
steve 1961  Offline
maryland
I am having trouble locating a new sending unit for a 4.3 fi tank. I have ordered from advance twice and the sending unit is not like the factory one. the 1/4 and5/16 lines look right but the 3/8line is just a slip fitting whereas mine is a threaded nut. the part number from advance is a spectra #fg08a. Is this what I will have to use? napa does not list one. my car is a 1987 pontiac grand prix with 4.3 fuel injection. thank you for taking time to read this, I know long post. Steve
#468852 - 08/09/07 06:30 PM Re: fi fuel tank sending unit [Re: steve 1961]
TPI Monte SS Offline
North Jersey
You will probably have to go to the source; AC Delco. Try to find a Delco dealer in your area as they should have the correct fitting on the end.
SSeeya,
Steve Ragusa - North Jersey
#468853 - 08/09/07 06:32 PM Re: fi fuel tank sending unit [Re: TPI Monte SS]
i think orangess has one for $100
#468859 - 08/09/07 07:27 PM Re: fi fuel tank sending unit [Re: tonys57chevy]
tri5ss Offline
tri5ss  Offline
Lebanon,Missouri
The last 4.3 sender that I bought from a A\C-Delco supplier 3 years ago had a slip on for the 3\8. I just got some AN fittings and made it a thresd on.
Cars Ain't Art!
They Are Meant To Be Driven!
#468884 - 08/09/07 08:54 PM Re: fi fuel tank sending unit [Re: tri5ss]
delmontess Offline
delmontess  Offline
woonsocket r.i.
go get one on ebay Item number: 200129748165 good luck i found this for you it for a 4.3 efi and it's ac delco new
monte ss goodwrench,350,world class,T-5,gn 342 posi,line lock, 3" drop in front 4" drop out back tpi is GONE back to the edelbrock
http://tonys57chevy.proboards.com/index.cgi
#468892 - 08/09/07 09:23 PM Re: fi fuel tank sending unit [Re: delmontess]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
I have never seen one with a screw on fitting. I have seen 3 of them. All were slip on with a "bubble" on it to keep it from slipping off once the clamp is on.
#468905 - 08/09/07 10:16 PM Re: fi fuel tank sending unit [Re: Tunedss86]
Yup, that's what mine looks like.
#468907 - 08/09/07 10:20 PM Re: fi fuel tank sending unit [Re: SS Ninja]
m0ntecarloss Offline
Windsor, NY
I bought mine from RockAuto and it had the threaded fitting. Unfortunately I don't remember what I chose for year, I will see if I have the part number when I get home.
86 SS - 1 billion horsepower vortec 355/WC T5/Megasquirt
#468912 - 08/09/07 10:28 PM Re: fi fuel tank sending unit [Re: m0ntecarloss]
Windsor, NY
Actually if you go to http://www.rockauto.com and look up part number:
25004938
The pic they have shows the threaded fitting. I'm not saying this is what I purchased for sure but it has the right pic at least : )
To find it I looked up the sending unit for an 86 4.3L Monte Carlo. I believe 87/88 monte carlo's had a different sending unit, maybe thats the problem.
#468949 - 08/09/07 11:53 PM Re: fi fuel tank sending unit [Re: m0ntecarloss]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
The one that I have use a 1/4" line for the return & a 5/15" for a vent. 1/4" line goes down past the pump to return fuel back into the tank without a lot of splashing & the 5/16" one ends up near the top to only get fumes. Are you guys seeing the same thing? Street & Performance told me I need to use a 5/16" as the return, but have used the 1/4" as the return with no problems.
#468957 - 08/10/07 12:05 AM Re: fi fuel tank sending unit [Re: Tunedss86]
Rockauto has the same one i have pulled out of every 4.3 car i ever partedout
#469390 - 08/11/07 02:29 AM Re: fi fuel tank sending unit [Re: tonys57chevy]
steve 1961 Offline
steve 1961  Offline
maryland
montecarloss, that looks like the one I need. Its discontinued from the dealer. maybe that 5% coupon from rock auto will come in handy! thanks for all the replies, Steve
by MikePEI
by mikeasis
500/thumbs/DSC01985.JPG
by msh1987
500/thumbs/Picture_177.jpg
by Big E's 83SS
500/thumbs/Picture_062a.jpg
by Tim3927
