I didn't want to hijack another thread. this is related to a front end rebuild I have most of the parts. was looking through an old gm parts book and they list a front spring insulator. The part number is still good.energy suspension does not list them. I don't want to take apart the front end and find that I need to replace them and have to wait with everything aparts.anyone who has done a ft end rebuild please let me know if the insulators are there . I will order them ahead of time if they are. thank you Steve
try your local Chevy dealer or a spring/suspension shop.
Mine were pretty flat and worthless. They r more for noise than anything else. To kkep the spring from metal to metal contact inside the frame. My new ones came from the dealer (had to order of course) and look like a piece of tire thats been cut off. I just used electrical tape to hold them on top of the spring during install.
I bought mine on ebay. I did the same thing (taped them to the top of the spring).
I taped my factory isolators like everyone else, but if yours are bad, just use a piece of rubber hose.
Dustin
87 SS
I would use something, I just put mine back together without the isolators in there and it sounds like theres a damn mouse under my hood. Like said before it just to prevent metal to metal contact. I would take mine back apart and put new ones in if it wasn't such a bitch to install the front springs
slow grandma car, 355, 3200 stall, 3.90s
thank you for all the replys. I will probably call the chevy dealer monday to order. Steve
there is no energy number because, just like bump stops, they are in a "universal" part of the catalog. You order them by dimension more or less, but I can assure you, energy carries something that will work just fine.
sick speed, I called energy suspension on 4/13/07 and spoke with tech support. they really don't list anything for front spring insulators even in the "universal" section.I even purchased a pair from the dealer for more accurate demensions. the tech said that there were no plans in the short term(6 months)for these. don't know if this will clear things up or not. Steve
You need to speak to someone else there then. Not only do they make them but they make them in either red or black and different thicknesses.
Here is one of the units that I used from Summit
http://store.summitracing.com/egnsearch....inresults=false
In fact I do not need them anymore since I went to coilovers, you can have them for $15.00 shipped.
1986 Monte Carlo SS, 427 SBC,
T56 6spd, Moser M9 3:70
SC&C G5,, Spohn Tubular A arms,
Pirelli P Zero 275-40x17 rear, 245-45x17 front
I got energy suspension spring insulators in my front end, 9-6120 and 9-6101 are good numbers. The 6120 needed the inside hole trimmed to fit over the tabs on the frame to center the spring.
86 SS
Iron-head LT1, 4L60E, GN 8.5"
All self-wired/installed/programmed
ZQ8's, Toyos, Blazer Brakes, Moog and SC&C, HRparts rear sway, ice cold A/C, too much to list..
2011 Audi S4 Prestige, M6, Brilliant Red
1997 K3500 Masons Dump, 454/4L80E
3 members (88ssBrent, PB86SS/87LS, Tunedss86), 52 guests, and 13 robots.
16,053 Registered Users
