#427557 - 04/06/07 10:32 PM
Re: .coil spring insulators, long question?
[Re: steve 1961]
try your local Chevy dealer or a spring/suspension shop.
#427579 - 04/06/07 11:29 PM
[Re: 86ttop]
85t5mcss
Indpls.,IN
Mine were pretty flat and worthless. They r more for noise than anything else. To kkep the spring from metal to metal contact inside the frame. My new ones came from the dealer (had to order of course) and look like a piece of tire thats been cut off. I just used electrical tape to hold them on top of the spring during install.
1985 Monte Carlo SS, T-Tops, 355cid w/ AFR 195s 409HP/429TQ, C5 Front Brakes, T5 5 Speed, QA1 Adjustable shocks/springs Front and Rear blah, blah, blah.......... Silly "Ricers", useless wings are for penguins!
#430102 - 04/13/07 07:51 PM
[Re: SickSpeedMonte]
steve 1961
maryland
sick speed, I called energy suspension on 4/13/07 and spoke with tech support. they really don't list anything for front spring insulators even in the "universal" section.I even purchased a pair from the dealer for more accurate demensions. the tech said that there were no plans in the short term(6 months)for these. don't know if this will clear things up or not. Steve
#430126 - 04/13/07 09:02 PM
[Re: steve 1961]
John S
Orange County NY
sick speed, I called energy suspension on 4/13/07 and spoke with tech support. they really don't list anything for front spring insulators even in the "universal" section.I even purchased a pair from the dealer for more accurate demensions. the tech said that there were no plans in the short term(6 months)for these. don't know if this will clear things up or not. Steve You need to speak to someone else there then. Not only do they make them but they make them in either red or black and different thicknesses. Here is one of the units that I used from Summit http://store.summitracing.com/egnsearch....inresults=falseIn fact I do not need them anymore since I went to coilovers, you can have them for $15.00 shipped.
1986 Monte Carlo SS, 427 SBC, T56 6spd, Moser M9 3:70 SC&C G5,, Spohn Tubular A arms, Pirelli P Zero 275-40x17 rear, 245-45x17 front
#430178 - 04/13/07 11:59 PM
[Re: John S]
spudmanmike
Waterford, CT
I got energy suspension spring insulators in my front end, 9-6120 and 9-6101 are good numbers. The 6120 needed the inside hole trimmed to fit over the tabs on the frame to center the spring.
86 SS Iron-head LT1, 4L60E, GN 8.5" All self-wired/installed/programmed ZQ8's, Toyos, Blazer Brakes, Moog and SC&C, HRparts rear sway, ice cold A/C, too much to list.. 2011 Audi S4 Prestige, M6, Brilliant Red 1997 K3500 Masons Dump, 454/4L80E
by javi05
by Matt?
by dw329
by zz485ss
