#34697 - 12/06/05 04:33 PM
Re: TPI Conversion
Sparkee
Central ILL
Before you do anything, buy this book: http://store.summitracing.com/default.asp?Ntt=sad+sa53&...=115&target=egnsearch.asp It is not specific to G-bodies, just TPI swaps in general. Your best bet for fuel pump is a fuel sending unit from a TBI Monte or GN/Turbo Regal with a Walbro pump. Another option, which is what I'm using on my 87 SS, is a frame rail mounted fuel pump from a mid-late 80's Ford F150. Don't ask why, I'm using it cause I got it free from a buddy that had a TPI setup on his truck and it works. You need some fuel line adapters to fit the Ford fittings, but I got those, too.
There is no such thing as too much horsepower, as long as you can put it to the ground!!
#34699 - 12/07/05 02:28 AM
Re: TPI Conversion
85SSMan
Wichita, Kansas
Dustin,
I found all the information for my swap at chevythunder.com and right her on this board. I used the factory TPI harness, and tied it into the Monte harness where needed (only a few wires), took me a total of about a week to get everything installed, tuned and running good. You will also need to look at Thirdgen.org for tuning tips, error codes and basic wiring for your TPI, the people there are pretty harsh, but will help if you ask the right questions.
Chris
 1985 Monte SS, Rebuilt L69 with TPI. 200-4R Tranny. 951 Modine with TPI duel fans. True 2 1/4 Flowmaster Duals. B.F.H. made dual hump crossmember. Stock Suspension, interior, and body. SOLD TO INTMDATR3 ON 03/04/06
#34702 - 12/07/05 04:27 PM
Re: TPI Conversion
ss4ever
Moderator 15+ Year
Moderator 15+ Year
Shelbina, Missouri
I bought my harness from a guy on ebay. I got a NEW harness, used ECM, all new GM relays, wiring diagram, instuctions, new Memcal(chip) with emmisions and VATS deleted and his phone number to call if I ran into any problems. He was very helpfull but looking back I would have changed a few minor things with the harness, nothing big, but would make the harness look nicer underhood. The guy started a website that he sells stuff through called http://www.eficonnection.com He sells fuel rails that relocate the fuel lines to the rear of the engine which would clean things up a bit IMO. Randy
#34703 - 12/07/05 07:18 PM
Re: TPI Conversion
Duts87SS
Spanish Fort, AL USA
Originally posted by NRW: No, the Howell harness does not include a ECM. I didn't think so, but the website shows the harness connected to an ECM.
Dustin 87 SS
#34705 - 12/09/05 02:49 PM
Re: TPI Conversion
Gruvin
Moderator 15+ Year
Moderator 15+ Year
Texas
Originally posted by Duts87SS: This system is coming from a 305. Would you guys suggest any initial mods for my Goodwrench 350 (stock except for headers)? Do I need to up the injector size or just up the pressure? Get a set of 19# SVO injectors, they are cheap as heck and worth it... DO NOT up the pressure to compensate, I dont care what those cheapskates out there say, I would not run my injectors above 80% duty cycle just to say 150.00, and especially with USED parts... you never know how long they will last before you have to tear it apart to replace one or more that are leaking or not working at all... No thanks!
My first SS! Sold Jan 2004 ![[Linked Image]](http://www.MonteCarloSS.com/images/Gruvin_84SS_sig.jpg) 87 SS bought 9-5-04: Sold 6-18-2010 - project 87 finds a new home with another undisclosed MonteCarloSS.com member!
#34710 - 12/09/05 03:40 PM
Re: TPI Conversion
Gruvin
Moderator 15+ Year
Moderator 15+ Year
Texas
Originally posted by Duts87SS: Would the PROM need reprogramming for use with these injuctor since the # rating is the same? Also should I jump on these injectors now? 105.00 buy it now is a very fair price. OPTIMALLY, the prom would need reprograming whether you use the increased pressure on stock injectors or up the injector size. Ford 19# injectors are more like 22# GM injectors so you are moving up to the 350 size at a cheaper rate than you would buying GM or aftermarket injectors like ACCEL, HTHs
#34712 - 12/09/05 07:25 PM
Re: TPI Conversion
TPI Monte SS
Moderator 15+ Year
Moderator 15+ Year
North Jersey
Originally posted by Gruvin84SS: OPTIMALLY, the prom would need reprograming whether you use the increased pressure on stock injectors or up the injector size. Ford 19# injectors are more like 22# GM injectors so you are moving up to the 350 size at a cheaper rate than you would buying GM or aftermarket injectors like ACCEL, HTHs Actually Jeremy, he's better off finding a set of 22s or 24s, especially for a 350. I have 19 lb. SVOs on my TPI 305, and according to the WB O2 readings from myd dyno runs and what my tuner says it's barely enough fuel. Plus, the guys over on thirdgen.org have said that the flow ratings on the SVOs really are the same as every other brand; Ferd uses a lower PSI to run their motor, but the injectors are flowed at the same rate.
#34717 - 12/09/05 08:50 PM
Re: TPI Conversion
SlowBlackCar
Edison, New Jersey.
Duts87, I'll sell my TPI that came off of a formula with a 350... with 22lb injectors
 Monte SS...gone... No more montes left... but I do have few Buicks...
#34719 - 12/09/05 10:10 PM
Re: TPI Conversion
TPI Monte SS
Moderator 15+ Year
Moderator 15+ Year
North Jersey
Jeremy, here's an interesting post from TGO - http://www.thirdgen.org/techbb2/showthread.php?s=...+performance+SVO+injector Basically, Rich at Cruzin' Performance (www.cruzinperformance.com) flowtested a set of SVO 36 lb. injectors at the GM rate of 43.5, and they did indeed put out the stated amount of 36 lb/hr. Check the 2nd post out in the thread for his flow numbers. If Ford really rated them at a lower PSI, they should have put out closer to 39 lbs. I'd guess that if someone sent in a set of 30 lb. SVOs or 24s that they'd be the same as well. Most of these injectors are made by Bosch, and flowed at the industry standard of (43.5 PSI). I still think he should go with the 24s, and just have the injector constant changed in the chip to 24 instead of 22. There are members on thirdgen.org are using the SVO 24s with no issues (other than the chip change).
by Ritttzz
by Savage 88
by Rebel87SS
by bug
by Aeroaddict
