#327993 - 06/13/05 11:19 AM Hotckis springs installed
JJMonteSS Offline
JJMonteSS  Offline
Detroit, MI
I just had my Hotchkis front springs installed the other day...car sits higher than it did with the original worn out springs. I searched the past threads and my ride height is right within specs, front is 27 inches and rear 28 inches. Should I expect this to lower once the springs settle?
The ride quality is great, very smooth over bumps and railroad tracks. I love the handling, just would've liked to be about one inch lower to close the gap between the fender and front tire. I'm running 245/45/17 up front and may go up to 50-series next time I get new tires just to fill the opening.
The rear looks very low and will bottom out with people in the back seat. I just ordered some Air Bags from Jegs to fill up when I'm hauling friends around. Other than that, KYB's and Hotchkis are a great combo.
'85 SS ZZ383, Extreme Automatics 2004r, 8.5 rear w/3.73 & Z06 brakes, Harwood hood, & Torque Thrust II 17's.
#327994 - 06/13/05 11:33 AM Re: Hotckis springs installed
TPI Monte SS Offline
North Jersey
They will settle, but not very much. Just make sure they're seated properly. They have to be right up in the spring pocket in the top, and the bottom end of the spring should tuck in between the two drain holes on the lower A-arm.
SSeeya,
Steve Ragusa - North Jersey
#327995 - 06/13/05 12:49 PM Re: Hotckis springs installed
JJMonteSS Offline
JJMonteSS  Offline
Detroit, MI
Do you know if the words HOTCHKIS should be right side up or upside down on the front springs? I looked and mine are not upside down, but it doesn't look like the shaved coil is on the lower a-arm...looks like a full coil but it's difficult to see. I'm going to call the shop that installed them and see if the guy remembers which end he used for top and bottom.
#327996 - 06/13/05 03:40 PM Re: Hotckis springs installed
JJMonteSS Offline
JJMonteSS  Offline
Detroit, MI
Well, I just called Hotchkis and they said that the letters should not be upside down so I am OK. He also said that they will not settle very much, only a 1/4 inch or less.
#327997 - 06/15/05 02:38 AM Re: Hotckis springs installed
RaGG Offline
RaGG  Offline
Memphis, TN
I have hotchiks front and rear springs and I'm still not satisfied with the ride height. I have no clearance problems with 2.5 exhaust and headers. ( maybe a tall speed bump will scrape the collectors)
When I swap over to alumheads and an alum water pump, that will take a decent amount of the front end. (mainly just the heads) its going to begin to look like the front is a little higher than the rear.
I don't wana jack the back up to compensate, and i want it a little lower in the front.
Are springs that drop it down further the key? or should i try some 2" drop spindles ontop of the 1" drop hotchiks springs.
Id hate to began to scrape everything on the road for looks.
gas guzzler
#327998 - 06/15/05 11:27 AM Re: Hotckis springs installed
JJMonteSS Offline
JJMonteSS  Offline
Detroit, MI
I was thinking the exact same thing except I am afraid of having the front tires smack the inner wheel wells when going over large bumps.
I'm really surprised with these Hotchkis springs because I had a set on an '86 Monte that I owned 5 years ago and that car sat about an inch lower than mine right now. I remember that I couldn't slide my floor jack under the engine without picking up on the body. Now, the floor jack has plenty clearance above it. I realize that every car is a bit different, but that seems extreme.
My "drag bags" just arrived yesterday so I'll put them in this weekend to raise the back slightly to level out the look. I'm also hoping that if I raise the back an inch, the front will be maybe a little lower...please...I don't like my Monte looking like my Silverado I drive in the winter.
#327999 - 06/16/05 04:47 PM Re: Hotckis springs installed
RocknSS Offline
RocknSS  Offline
Shirley, NY
My 85 SS has the full Hotchkis kit, springs, sways, trailing arms, etc, with KYB gas shocks, The car site and easy 1" lower (it was immediately noticeable) and handles awesome!!!
My nose came up a little once I dropped in the ZZ4 w/aluminum heads, took out MOST of the AC stuff, the AIR pump and dropped on a Harwood fiberglass hood. That lightened the front a bit, but I am still happy with the stance, aggressive, lower and looks good at the current height too. Definitely lower than the stock ride height.
1985 MCSS-ZZ4, Eddy headers, custom tuned Q-Jet, CK stage 2 2004r, Hotchkis TVS, ZQ8 wheels and cowl hood
1986 Monte SS - mostly stock
#328000 - 06/16/05 06:48 PM Re: Hotckis springs installed
spudmanmike Offline
spudmanmike  Offline
Waterford, CT
I'm in the same boat.. My rear dropped 1" while the front only went down 1/2", if that. I had to put airbags in the rear to get the height back up to make the car look proportional. But the bags are a good thing because I can carry a tranny in the trunk and the rear sits normal \:\)
On the spring note, I can't remember which way the words are.. I put them in upside down the first time. Check this picture out - The stock spring is in the correct direction, the hotchkis spring is upside down. The tighter wound coils go on the top:
http://home.comcast.net/~spudmanmike/ftsprings.jpg
86 SS
Iron-head LT1, 4L60E, GN 8.5"
All self-wired/installed/programmed
ZQ8's, Toyos, Blazer Brakes, Moog and SC&C, HRparts rear sway, ice cold A/C, too much to list..
2011 Audi S4 Prestige, M6, Brilliant Red
1997 K3500 Masons Dump, 454/4L80E
#328001 - 06/17/05 10:33 AM Re: Hotckis springs installed
JJMonteSS Offline
JJMonteSS  Offline
Detroit, MI
I just installed the air bags last night and drove the car to work for the first time this morning!! The ride quality is very good..not too bouncy. I only have about 5 psi of air in the bags and that raised the rear an inch. It looks much better now that the car's not dragging it's tail.
#328002 - 02/02/06 02:59 AM Re: Hotckis springs installed
bradleyls103 Offline
Imlay City, MI
Man jjmontess has al the cool stuff. I need to get a job where he works, lol. Very cool!
Bradley
#328003 - 02/02/06 03:58 AM Re: Hotckis springs installed
McssGmachine Offline
Arlington, TX
Dude, I have hotchkis sping on my car and it didnt drop it that much. I think i have about 3" between the wheel well and tire. I'm going with OPG 3" drop spings this spring.
#328004 - 02/02/06 11:16 AM Re: Hotckis springs installed
ZZ430T56 Offline
ZZ430T56  Offline
Central Virginia
Same here. Hotchkis springs front and rear. Didnt drop much if any.
....Bill
Bill Rossi
88 Monte SS
ZZ430 350/430hp
T56 6 speed
Ford 9"
WEBPAGE: Bill's 88SS
#328005 - 02/04/06 03:28 AM Re: Hotckis springs installed
79MeanGbody Offline
79MeanGbody  Offline
Columbus Grove, Ohio
Same here. They ride firm but not harsh. Just what most are after except maybe a little lower. I wonder how they would be cut a half to full coil or so.
'79 Cutlass
-10:1 Crate 350 - Worked Vortecs - XE274 - Edelbrock 750
-Hedman Long Tubes - 2.5" True Duals - X-pipe - Dynomax Bullets
-T56 6 Speed - LT4 PP - RAM Powergrip - Pro 5.0
-8.5 Grand National Rear - Posi - 4.10s
-Hotchkis Springs & Sway Bars - Boxed Rear Control Arms & 1LE Bushings
-F41 Frame Braces - PST Front End Kit - XH Steering Box
500/thumbs/IMG_1088.jpg
by Frazier85
500/thumbs/mymonte2.jpg
by 85PrimeredMCSS
500/thumbs/Photo0186.jpg
by benen
500/thumbs/Glen.jpg
by PontiCarlo468
500/thumbs/DSC01986.JPG
by msh1987
