#252630 - 06/10/05 06:57 PM does htis sound like a starter going??
l3lue Offline
l3lue  Offline
Orlando
my buddy's '84 grand prix seems like it is having a little starting trouble...when he goes to start the car it seems like the car is struggling to turn it over..though it does turn over..it kinda seems weak...like if it was a dying battery, but i think the battery is good...do starters slowly die or do they just die at once?
#252631 - 06/10/05 07:12 PM Re: does htis sound like a starter going??
Radiant Heat Offline
Wild, Wonderful, West Virginia
I've had em go out both ways. If the battery is definitely good, I'd go ahead a put a new (or rebuilt) starter in it... may save a major headache some night in the middle of nowhere, but that's just me.
Burgundy 88 MCSS, T-Tops, A/C, Cruise, ZZ383, MSD6AL, MSD wires, K&N, 8.5 rear, 2-1/2" true duals, Edelbrock RPM Air-Gap, Demon 750, Hooker 1-3/4" headers, Edelbrock Shocks, Holley line lock, INDY 500 235/60/15 F&R (Hoosier QT Pro 27x10.5x15 for the track), Goodmark hood.
#252632 - 06/10/05 07:33 PM Re: does htis sound like a starter going??
Hoserfive Offline
Hoserfive  Offline
Kirkland- Washington
I would check the grounds first make sure there clean and tight before I started throwin money at a problem I was not sure about !
Hoserfive
86 SS Black/grey int...car is into a new stealth mode...when will it ever end ?
#252633 - 06/11/05 07:10 PM Re: does htis sound like a starter going??
Draxx'87SS Offline
Lurker
Draxx'87SS  Offline
Lurker
Not Here, USA
#252634 - 06/11/05 07:30 PM Re: does htis sound like a starter going??
Joe87monteSS Offline
Memphis,TN
I had a starter do just that. It would turn the motot over slowly, but wouldn't start. It would drain the battery real fast too! Put a rebuilt starter on there, and charged the battery and all was good.
Joey
Engine/head builder/machinist
2004 Silverado
Facebook
#252635 - 06/13/05 09:36 PM Re: does htis sound like a starter going??
volvotech Offline
volvotech  Offline
Hudson New Hampshire
If the armature (the part that spins in the starter) has a short to ground it will spin slowly,have no torque and drain the battery.I'd check for bad connections at the battery first. You can do a voltage drop test on the starter.Put a Volt meter across the battery.The voltage shouldn't drop below 9 volts while cranking.If the battery is good and it drops way below that,the starter is no good.
Volvotech
500/thumbs/IMG_0398s.jpg
by Turbo5
500/thumbs/0051.JPG
by SSPARKY
by Duster
500/thumbs/door_panel_1_.jpg
by Rodney
500/thumbs/th_ss004-1.jpg
by sstwotimer
