#245121 - 10/13/05 12:34 AM computer
turbe Offline
turbe  Offline
Darlington S.C.
removeing computer from car, I understand that I have to change cc carb. & cc dist. what brand of dist, carb, intake, this mcss is a grocery getter , it will not be raced or driven hard, it will be babyed.but when I have to pass a car in front of me , I want to get it done, all suggestions would be appreciated. I am restoring this mcss 86, I have approx. $9000.00 so far , so I don't want to blow a lot more money,on carb.,dist. intake
#245122 - 10/13/05 12:39 AM Re: computer
ss4ever Offline
ss4ever  Offline
Shelbina, Missouri
If you are just gunna do that with it then why not just beef up the carb and ignition, would be cheaper than a new carb, distributor and lockup kit. If anything there should be some place near you that can build up your carb to make your car scream and go with a MSD box.
That would be good enough for what you are gunna do.
Randy
#245123 - 10/13/05 10:07 PM Re: computer
PontiCarlo468 Offline
Arcadia, Florida
The best IMO for a Daily Driver/Grocery Getter is the Edelbrock Performer Plus Intake/Cam Combo... Excellent results on a otherwise stockish motor... HTH
1987 Monte Carlo SS- Off The Road For Restoration... Then Street/Strip action when done!!!
1987 Chevy Caprice Wagon- New Daily Driver. Olds 307/TH-2004R/2.73s
Sargent Of Arms Of Maniacs Minions.
Glen502@hotmail.com
#245124 - 10/13/05 10:10 PM Re: computer
KYKilla Offline
KYKilla  Offline
Louisville, KY
I left the computer,carb,dist, put cam/intake/headers and pulled 207 rwhp. Had great passing power. And I have an extra qjet if you wanna rebuild one.
#245125 - 10/14/05 01:57 AM Re: computer
85SSMan Offline
85SSMan  Offline
Wichita, Kansas
before I put in my TPI, I was using an Edelbrock 600 cfm carb, with a standard vaccumm advance dist($40 at parts store), and just put on the carb plate adapter for the square bore tp spread bore. The SS already has a decent intake, no need to change it if you are just driving around, but like randy said you will need a Lock Up kit for your Trans.
Chris
SOLD TO INTMDATR3 ON 03/04/06
#245126 - 10/14/05 12:33 PM Re: computer
Damon Offline
Damon  Offline
Philly area
The easiest bolt-ins would be NON-computer controlled versions of the QJet carb and HEI distributor. Literally bolt-ons in every way. If you want to change intakes the Edlebrock Performer or Performer EPS are likewise bolt-ons and might be worth a few HP (plus removing some weight!) over stock.
I do my own QJets so for me they're cheap. Otherwise, a performance-tuned QJet would run you about as much as any other brand/type of carb. All your stock cables, fuel line, etc. will hook right up. A performance-oriented HEI distributor can be had these days for under $150 complete. Your stock wiring will even hook right up to it with no changes.
78 Malibu. Grandmother's old car with 33K original miles. Mild 383 with a Weiand 142 blower. New Redneck 2700 stall blower converter assures zero traction under all conditions.
1990 454 SS truck. All stock with a rod knock. Screwing together a nasty little solid lifter heavy-breathing big block to replace it.
500/thumbs/PB050593.JPG
by STINGER-427
1166/thumbs/106677_330589ec9d_low_res.jpg
by lonk
500/thumbs/cid_279.jpg
by Joe87monteSS
500/thumbs/1987_SS_R_.jpg
by badSScarlo
564/thumbs/oscars_LS_MONTE_CARLO_019.jpg
by Big Reazon
