#235968 - 06/01/05 07:27 PM Removing window sealant from glass
DEIAero Offline
DEIAero  Offline
Hobart, IN
Got the quarter windows out of the car and have some of the sealant still on the glass. Just wondering what is the best thing to use to get this sticky stuff off?
87 T-Top Aerocoupe, under restoration
#235969 - 06/01/05 08:36 PM Re: Removing window sealant from glass
Aeroaddict Offline
Aeroaddict  Offline
Fairfield County ,CT
Try a razor blade.
#235970 - 06/02/05 01:13 PM Re: Removing window sealant from glass
lacquer thinner
#235971 - 06/03/05 09:33 PM Re: Removing window sealant from glass
Draxx'87SS Offline
Lurker
Draxx'87SS  Offline
Lurker
Not Here, USA
#235972 - 06/04/05 12:04 PM Re: Removing window sealant from glass
THEMEYER Offline
THEMEYER  Offline
highridge mo.
lighter fluid that is what windsheild installers use to soften the sealer to remove the windsheilds or i found that 3m general adhesive remover work wonders on everything from road tar to bugs with out hertting the paint i use it on my white 84ss all the time but it will remove the wax to
DANIEL R MEYER
#235973 - 06/04/05 01:16 PM Re: Removing window sealant from glass
supernova455 Offline
tampa, fl usa
I ahve done what Draxx described, it's like the snowball effect.
Supernova455
#235974 - 06/04/05 04:41 PM Re: Removing window sealant from glass
502SS Offline
502SS  Offline
Carson City, Michigan
Supernova455
Same here
'83 Cutlass...project cheap...11.40's so far on a budget
'76 Jeep CJ5...430 SBC on spray
#235975 - 06/04/05 07:50 PM Re: Removing window sealant from glass
MY FYN 79 Offline
MY FYN 79  Offline
N/E WI
Originally posted by aeroaddict:
Try a razor blade.
A new razor blade removes stuff from glass very well.
#235976 - 06/06/05 11:48 PM Re: Removing window sealant from glass
badSS502 Offline
badSS502  Offline
Zephyrhills Florida
W-D 40 works wonders on glass
#235977 - 06/08/05 10:07 AM Re: Removing window sealant from glass
redss86 Offline
redss86  Offline
Greenville, IL
If you still have the trim on the glass, don't use a razor blade. You could cut the rubber on the trim and ruin it.
Originally posted by Draxx'87SS:
If it is still sticky...use itself to get it off; that butyl sticks to itself very well...so you take some of the bulk you removed and roll it on there to get the remaining to stick to the bulk and it will come off. I hope that makes sense.
I have used this method many times. It is much cleaner than using solvents. The only thing is your hands will probably turn black from the sealer. After you get the majority of it off like this, then I would recommend 3m adhesive remover to clean the rest off.
Good Luck,
redss86
#235978 - 06/08/05 03:22 PM Re: Removing window sealant from glass
Draxx'87SS Offline
Lurker
Draxx'87SS  Offline
Lurker
Not Here, USA
500/thumbs/IMG_0398s.jpg
by Turbo5
500/thumbs/0051.JPG
by SSPARKY
by Duster
500/thumbs/door_panel_1_.jpg
by Rodney
500/thumbs/th_ss004-1.jpg
by sstwotimer
