#196937 - 10/13/04 11:00 AM Cleaning underside of hood
JJMonteSS Offline
JJMonteSS  Offline
Detroit, MI
I have a harwood glass hood and the underside needs to be cleaned. I had a small oil leak and it sprayed the underside of the hood. I have tried using simple green and it didn't clean it up as well as it should have. Any suggestions would be appreciated, the underside is painted satin black--not a high gloss, if that makes a difference.
'85 SS ZZ383, Extreme Automatics 2004r, 8.5 rear w/3.73 & Z06 brakes, Harwood hood, & Torque Thrust II 17's.
#196938 - 10/13/04 10:25 PM Re: Cleaning underside of hood
BigWheels-SS Offline
Apple Valley, California
JJ
I've never seen Harwood glass. But I've found that almost any kind of car wax and the finest steel wood will clean up the harshest of chemicals. Just use the steel wool like a wax pad and make sure you a lot of wax on the steel wool as to not scratch the surface.. Try a small spot and see the results. If it works, I'm happy for you, if it doesn't, I'll ask my homy and let you know by friday or saturday.
#196939 - 10/14/04 12:51 AM Re: Cleaning underside of hood
200kSS Offline
200kSS  Offline
Bloomsdale, MO
If the underside isn't finished (just rough fiberglass) I'm not sure how to clean it. Might be soaked into the fiberglass by now.
#196940 - 10/14/04 09:48 AM Re: Cleaning underside of hood
Scott_86SS Offline
Scott_86SS  Offline
North Pole, AK (no, really!)
Soak it with a good degreaser and then use a pressure washer. Or would damage the fiberglass?
scott.leppert@acsalaska.net
'86 SS, White/Gray, T-Tops, Full Stock, L69 305HO, Flowmaster 40s
--20 yrs yearning, 2 yrs searching, 1 wk purchasing, lifetime of enjoyment
#196941 - 10/14/04 10:37 AM Re: Cleaning underside of hood
JJMonteSS Offline
JJMonteSS  Offline
Detroit, MI
I usually use Simple Green as a degreaser on the engine, but that didn't cut it. Maybe I should try to use GUNK or Gumouts SteamClean on the hood. I'll try a small spot to see if it works.
#196942 - 10/15/04 09:50 PM Re: Cleaning underside of hood
johnnymag3 Offline
johnnymag3  Offline
Millbrook, New York
Gumouts steam clean is an excellent product...I use it on my Wheelhorse tractor....it is awesome..!!!!!!!!!
The day we stop learning, is the day we stop living.....
#196943 - 10/21/04 06:29 AM Re: Cleaning underside of hood
WickedSS Offline
WickedSS  Offline
Stafford, Virginia
Im thinking, at the shop when I spill some oil, I use old rags and let them sit for at least 12 hrs. When I lift the rags, everything is pulled from the floor.
So... maybe as an extra absorbant, place some Baby Powder on a rag and tape it overnight on the oil spot???? <--dunno what yall think?
I use BP often on our Suburban 24 hrs before vacuuming, it's damp sometimes... seems to work well
1979 MONTE CARLO LANDAU ONE STEP AT A TIME
#196944 - 10/29/04 11:11 PM Re: Cleaning underside of hood
Slick SS Offline
Slick SS  Offline
Knoxville,IL
Just go to the car wash and spray it off with the cleaner.Cover the carb if you have an open air cleaner.It cleans the oil off because the wash cycle uses hot water.
My "Baby" is a 1986 SS that is White with the Burgandy int.She is all stock with a couple small additions,Trunk light and Remote release.It has almost 69K on the speedo and runs strong and smooth.UPDATE!!First time to drag strip tonight.6/15/02 6 runs with best reaction of .162 and best ET of 15.71.
#196945 - 02/02/06 12:34 AM Re: Cleaning underside of hood
bradleyls103 Offline
Imlay City, MI
Dish soap and a wash rag will really clean it up.
Bradley
1096/thumbs/DSC09166.JPG
by NC87AERO
500/thumbs/100_04901.JPG
by Bad85LS
500/thumbs/mcsusp2.jpg
by javi05
500/thumbs/IMG_0356.JPG
by 565bbchevy
500/thumbs/downsized_0330121649.jpg
by blkcharlotteman
