#16803 - 01/19/06 09:04 PM changing oil pan gasket
SSMonte_Man125 Offline
San Tan Valley, AZ
Well my front seal on my oil pan is leaking pretty bad, and it needs to be replaced and i just dont feel like doing it because its such a pita ... should i just bring it to a shop and have them do it, how much you think they would charge?
87' Monte Carlo SS vortec 350, VooDoo 437/454, 670 street avenger, HEI dist, AC/heater delete, Stock 373
13.3 @ 101 1.9 60ft-(garaged needs trans overhaul)
-07' Tahoe Z71
-12' Cruze 1.8l ecotec 6spd (gas sipper)
#16804 - 01/19/06 09:37 PM Re: changing oil pan gasket
AT6CL Offline
AT6CL  Offline
Queens, NY
I wouldn't be surprised if they tried to charge you $100.00. Should be an easy job for the DIY'er. Drain and drop the pan, R&R the gasket (I've been meaning to try the one-piece jobs), replace the pan, fill with oil. I'm sure I missed something though, LOL :rolleyes:
Leader of the "No Clone" movement.
'86 SC/CL 79,000 miles. "Work in Progress". 383/2004R/Posi 3.73 build-up in the works.
"Bust your ass during the week . . . bust your knuckles on the weekend."
#16805 - 01/20/06 02:25 AM Re: changing oil pan gasket
ss4ever Offline
ss4ever  Offline
Shelbina, Missouri
It's a chore to replace the gasket with the engine still in the car. Would be almost as easy to pull the engine to replace the gasket. You are gunna need to unhook the motor mounts, exhaust, flywheel cover and lift the engine and then remove the oil pan and I think the oil pump at the same time.
I have gotten away with washing the area up real well with brakclean(it degreases real well!) then just put some silicone on the tip of my finger and push it in the hole. Takes a little bit but if everything is dry when you do it the silicone should do the job.
Randy
#16806 - 01/20/06 02:39 AM Re: changing oil pan gasket
85SSMan Offline
85SSMan  Offline
Wichita, Kansas
Randy's right, you will have to lift the engine in order to replace that gasket. I have done the silicone job myself a couple times with decent sucess.
HTH
Chris
SOLD TO INTMDATR3 ON 03/04/06
#16807 - 01/20/06 04:02 AM Re: changing oil pan gasket
baaboo Offline
baaboo  Offline
Racine, WI
I'll also jump on the silicone wagon too. If you do it right like ss said, it will be hard to clean it off when you WANT to!
#16808 - 01/20/06 12:49 PM Re: changing oil pan gasket
Harlan Offline
Harlan  Offline
Lansdale, PA USA
I've done it twice-both times I've left motor in car, but its a PAIN. Don't have access to hoist...
Anyhow, 1st time I did it, I took the pan off and you have to take bolts out from motor mounts, exhaust, starter, and remove distributor in order to tilt engine. This gives barely enough clearance to get pan out.
2nd time, I just dropped pan (still had to bend exhaust, remove starter) It's a little easier, except when you drop one of the end seals into the pan. Ended up fishing it out thru the oil pan bottom plug....
It $ucks either way.
#16809 - 01/20/06 06:44 PM Re: changing oil pan gasket
Silicone worked on my old 305 like a charm... I even used to old, early style seal (thinner of the two) by mistke, and the silicone fixed that mistake.
Clean it really well, and force the sealer into the leak. Put a nice bead around the area, adn let it cure overnight.
#16810 - 01/20/06 07:26 PM Re: changing oil pan gasket
1984 MonteManiac Offline
tax york
That is not aan easy job...I pulled my motor up 5 inches to do that job....
I hate know it alls and doubting toms.
772/thumbs/DSC00143.JPG
by NVD_SS
500/thumbs/IMG_1089s.jpg
by Turbo5
923/thumbs/P4180057.JPG
by SSilverSStreak
500/thumbs/resize11.jpg
by shades
500/thumbs/CAR_SMALL.jpg
by 87 monte
