#187651 - 06/13/05 10:12 AM Cruise control went out
Abraham Offline
Abraham  Offline
san diego, ca
Anybody know what I should check for? my cruise control went out one day while using it. All hoses are connected and in good condition. I think its electrical. Any suggestions would be greatly appreciated.
#187652 - 06/13/05 10:47 AM Re: Cruise control went out
Check the diaphram under the hood. The bracket (mounted on the diaphram itself) that connects the diaphram and the rod linkage tore once on my '84 and I had to replace it.
#187653 - 07/21/05 02:54 PM Re: Cruise control went out
You should just remove it... it gets in the way of your clutch master ;\)
#187654 - 07/21/05 04:42 PM Re: Cruise control went out
200kSS Offline
200kSS  Offline
Bloomsdale, MO
But it makes Power Tour sooo much easier!
Check the vac. diaphram under hood, but if its electrical the cruise switch (turns signal lever) is most likely the problem.
#187655 - 07/21/05 11:31 PM Re: Cruise control went out
ProTourAero Offline
ProTourAero  Offline
Chesterton, IN
I would also check the release switch next to the brake light switch. It may just be out of adjustment.
1987 Monte Carlo SS Aerocoupe "Pro Touring", 436ci All Alum. SBC, 18 Aluminum Heads, 700R4, 3000stall, Ford 9 inch, 3.90 gears, 620 H.P., 590 FT LBS Torque. E.T. 11.229 @ 123.62 on motor. 10.213 @ 137.58 NOS (10/02/2010)!
www.protouraero.com
#187656 - 07/22/05 01:25 AM Re: Cruise control went out
85SSMan Offline
85SSMan  Offline
Wichita, Kansas
Look in the Tech section for my write up on Cruise Control. It tells you a lot. Need a little more detail of what is happening and we will get you fixed up.
Chris
SOLD TO INTMDATR3 ON 03/04/06
#187657 - 07/22/05 09:13 PM Re: Cruise control went out
SBF-W86SS Offline
SBF-W86SS  Offline
Oakland NJ/McGuire AFB NJ
our cars have or had cruise control?
Steve - 1987 White SS performer intake, flowmaster, k&n air cleaner
my other ride is a KC-10 extender. NKAWTG!
#187658 - 07/23/05 01:02 AM Re: Cruise control went out
85SSMan Offline
85SSMan  Offline
Wichita, Kansas
most MCSS had Cruise Control, yes.
#187659 - 07/25/05 07:35 AM Re: Cruise control went out
Abraham Offline
Abraham  Offline
san diego, ca
I think it is electrical, the check engine code that I got before it went out was the VSC error. The vacuum line is hooked up. Where is the release switch and what should I look for? It was working until it shut off on me while driving.
#187660 - 07/25/05 07:38 AM Re: Cruise control went out
Abraham Offline
Abraham  Offline
san diego, ca
Sorry, current problem: won't turn on at all, resume, set, or accelerate.
#187661 - 07/27/05 01:25 AM Re: Cruise control went out
85SSMan Offline
85SSMan  Offline
Wichita, Kansas
593/thumbs/Daytona_Monte15.JPG
by 88MonteLSguy
500/thumbs/Wheel.jpg
by RocknSS
531/thumbs/bowtie.jpg
by tonys57chevy
500/thumbs/54.JPG
by Mark's SS
500/thumbs/before1.jpg
by spazzz86
