#185809 - 10/05/05 10:36 PM My Electrical Nightmare
RyankMCSS85 Offline
RyankMCSS85  Offline
Milford, MI
Ok where do I start...
I did a motor swap on my monte making it non-computer controlled. And since then the car cannot hold a charge for anything. Since then Ive went through 3 batteries 2 alternators and a starter. And still the battery is dead after about 3 days. So we went to test my alternator today by unplugging the battery while the car was running and it kept dying. But my alternator works and we have even switched my buddies alternator with mine. We have no clue what the problem could be Is there any chance the pin that connects into the side of the alternator is giving no juice. Please help im at a loss for words and ready to sell the car
white 85 monte ss with a 335 stroker, flowmaster th350, 3.73 posi
GO VIKES!
#185810 - 10/05/05 10:54 PM Re: My Electrical Nightmare
RyankMCSS85 Offline
RyankMCSS85  Offline
Milford, MI
anyone?
GO VIKES!
#185811 - 10/05/05 11:08 PM Re: My Electrical Nightmare
RyankMCSS85 Offline
RyankMCSS85  Offline
Milford, MI
ttt
GO VIKES!
#185812 - 10/05/05 11:36 PM Re: My Electrical Nightmare
bkrossch Offline
bkrossch  Offline
Madison, WI
There could be a variety of issues causing your electrical problem.
1.) Your alternator charges at the appropriate voltage but does not provide enough current. In this case, the voltage regulator or alternator would have to be replaced (unlikely as you said you did this a few times already)
2.) You have a "ground loop" somewhere in your car which is causing the battery to drain. This could be due to a broken ground wire between your block and frame, or frame and body, or that your car may actually have two separate grounds which are aphysical. As an example, measure the potential between the ground on your gauge cluster, for example, and the negative terminal of the battery. If you read more that a few millivolts, you have a problem.
3.) If your car keeps dying when it is running and you remove the alternator, and you believe the alternator is good, then you can start to reduce down the possibilities of why it stalled. Did it stop getting spark? If so, you're not getting voltage to your ignition system...etc. etc. etc.
There are so many parts to the electrical system that could have problems...you just have to start narrowing it down one by one, system by system, wire by wire. If you do it meticulously, I'm sure you'll find the offending wire/short/ground that is giving you your problem!
A good mechanic would know where to start - maybe Randy or one of the other guys on the board can give you some advice. A lot of guys here have a lot of experience repairing these cars - I haven't worked on mine enough (or had enough problems with it) to give you a starting point. In the Powertrain Controls Lab where I work at UW, I know we ran into a problem in the TPS circuit of a new Ford motor which mysteriously changed its ground depending on whether or not the fuel pump was on. This being a brand new 2006 Duratec 3 liter. It happens I guess.
-Brian
Brian
1986 Monte Carlo SS
My Homepage
#185813 - 10/05/05 11:44 PM Re: My Electrical Nightmare
beachbum29 Offline
beachbum29  Offline
Upstate, Ny
2 questions... well, actually 3..
did the car charge ok prior to changing the engine, and taking off the computer stuff?
are you sure you've got all the wires hooked up in they're proper locations?
did you chop out the harness, or leave it intact so you tie it up out of the way? (just in case you missed something??)
1978 Malibu 355/4 speed/posi/gauge's soon to be BBC....
1988 Monte SS (getting 355 from 'bu)
2003 HD softail...... new hotrod...
2000 Chevy Silverado 1500 ext cab..
http://www.beachbumstoybox.zoomshare.com/
#185814 - 10/05/05 11:52 PM Re: My Electrical Nightmare
RyankMCSS85 Offline
RyankMCSS85  Offline
Milford, MI
thanks guys....
The car chardged fine b4 the motor swap when i had the car stock. IM pretty sure i have everything in the right place even had a mechanic look. I have the wires just hanging out of the way i do not have the harness removed
GO VIKES!
#185815 - 10/06/05 12:03 AM Re: My Electrical Nightmare
RyankMCSS85 Offline
RyankMCSS85  Offline
Milford, MI
would the ground on the block cause my alternator to not work
GO VIKES!
#185816 - 10/06/05 12:25 AM Re: My Electrical Nightmare
beachbum29 Offline
beachbum29  Offline
Upstate, Ny
i've seen different things go weird when that ground isn't hooked up.. . not sure if that would effect charging, but it can't be helping.
#185817 - 10/06/05 05:46 AM Re: My Electrical Nightmare
Lonewolfe Offline
Lonewolfe  Offline
Macon,Ga
First off did you unhook or modify anything from the alt. circuit ? Second,what about you charge back wire from the alt.to battery?Is the little ground wire the negative cable still hooked up on your inner fender?
What is it that most people don't have? Answer....POWERS OF OSBERVATION.
#185818 - 10/06/05 09:47 AM Re: My Electrical Nightmare
RyankMCSS85 Offline
RyankMCSS85  Offline
Milford, MI
No we didnt modify anything from the circuit. And everything is hooked up properly including my negative ground
GO VIKES!
#185819 - 10/06/05 06:06 PM Re: My Electrical Nightmare
RyankMCSS85 Offline
RyankMCSS85  Offline
Milford, MI
anybody else with any suggestions im lost here
GO VIKES!
#185820 - 10/06/05 08:10 PM Re: My Electrical Nightmare
IndyJimW Offline
IndyJimW  Offline
Indianapolis,IN
Most vehicles equipped with an alternator will die if you disconnect the battery. I don't think it has anything to do with the battery, alternator etc. or even the engine swap.
You probably have a circuit on that is draining the battery. Disconnect the positive battery cable and hook up a DC voltmeter in-line, unplug electrical devices or pull the fuses until the meter drops from 12 volts to 0.
"They'll get my gun when they pry it from my cold, dead fingers. But that's not exactly 'Plan A'."
'87 Avanti - Heart of a SS, Body and Soul of a Studebaker!
http://www.picturetrail.com/gallery/view?p=999&gid=8110297&uid=3920570&members=1
#185821 - 10/07/05 12:57 AM Re: My Electrical Nightmare
SSteve Offline
SSteve  Offline
PA
do you have the alt wired up correctly? there isa wire on it that goes from top to back
86 Monte Carlo SS,Stock L69 H.O.
200 4 R Trans with B&M Trans Pak stage 2 mods 15.80 @ 84 mph
#185822 - 10/07/05 01:36 AM Re: My Electrical Nightmare
85SSMan Offline
85SSMan  Offline
Wichita, Kansas
If you can get your car to Advance Auto Parts, or a parts store that can test batteries in the car, you will be able to figure out what is causing your drain. If you are positive you have everything hooked up right, then you have something draining you battery. Go have your car tested, The machine that runs that test has a voltmeter that just clips over the battery cable (like a timing light on the plug wire), with the car off, and igniition off there should be little to no volts reading (.0 -- .03) is acceptable. If it is more than that you have something draining you battery, with the battery tester still hooked up start pulling fuses one by one, after each one see in the voltage drops to the acceptable level, if no change put the fuse back and try the next one, when the voltage finally drops you have found the circut that has a fault. Search the circut for bad wires and repair. In all my years of Parts Sales a draining problem is almost always a radio, or something of that nature that has been installed wrong.
Chris
SOLD TO INTMDATR3 ON 03/04/06
#185823 - 10/07/05 03:02 AM Re: My Electrical Nightmare
RyankMCSS85 Offline
RyankMCSS85  Offline
Milford, MI
Ok guys I appreciate all your advice now its time to get to work
GO VIKES!
#185824 - 10/07/05 06:52 PM Re: My Electrical Nightmare
Fraser's 87 SS Offline
Brownsburg, Indiana
The easiest way to see where power is being drained from that I know of is to disconnect one side of your battery, take a volt meter and bridge the two connections so that the current is going through the volt meter and giving you a proper reading. have a friend go and start pulling fuses one by one replacing them if there is no change in voltage. when you do this you should notice a drop in voltage when you pulled the fuse on the bad sector. then you can just trace down what is all on that sector and then check the wires to and from.
I helped do this on a buddy's car and we eventually fixed it.
Hope This Helps
Patrick
zx14 kawi currently & an 81 Blue Bu
500/thumbs/Photo_car001.jpg
by troublesnc
500/thumbs/5-5.jpg
by dh85ss
500/thumbs/wheels_0011.jpg
by woodss
1129/thumbs/28.JPG
by GBODY88
500/thumbs/n1529049019_30029579_9636.jpg
by devider440
