#133180 - 10/14/06 05:06 AM FIRST RUN WITH THE 383
SMITHFOG Offline
SMITHFOG  Offline
SUN LAKES, ARIZONA
First pass - almost put it sideways and had to back down.
Second pass I really grandpa'd it off the line, 60' of 2.85, and ran a 14.4 @ 99.8 mph.
The 255/60 tires gotta go.
'83 SS, 383 Stroker, Edelbrock Aluminum Performer RPM Heads, AirGap, 750 Holly HP, Forged Rotating Assembly, Hookers, 3" TorqueTech, Hughes TH350c with 3200 Stall, Eibach Spings, Performance Suspension Polygraphite, Serpentine Belt System, dual 12" Spal fans, 8.5 with 4.11 gears, NX Twin 150 Shot, 11.29 @ 121.52 best.
#133181 - 10/14/06 05:34 AM Re: FIRST RUN WITH THE 383
Aceprowler Offline
Aceprowler  Offline
Erie, Pa
Isn't that a high MPH for 14.4!!
With better traction, the 13's she will be!
Great run anyhow!!
1984 Monte Carlo SS - "010" 4bolt 350, GN 8.5, 700R4, 3.42
#133182 - 10/14/06 05:22 PM Re: FIRST RUN WITH THE 383
First Project Offline
Pittsburgh, PA
Originally posted by SMITHFOG:
, 60' of 2.85,
omgroflmao! my stock 305 could take you off the line and it's in 215's!
Man, those street tires gotta go, you really need dr's and a posi if you dont already have one. Ge the 60' to like a 2.0-1.8 and you might be in the low 13's. with a sucky launch you may still have a lot more mph in that combo. Maby high 12's? cheers!
-Sean- Project "SStealth"
86ttop: That will buff right out.
tri5ss: Maybe with a 36 grit sanding disc!
#133183 - 10/14/06 06:10 PM Re: FIRST RUN WITH THE 383
realsurfer88 Offline
Tallahassee
he said it almost took it sideways,sig says auburn...there is a posi in there. were you letting it auto shift or bumping it? I dont neccessarily think that 12's or high 12's will come of a better launch but im thinking maybe mid/mid-low 13's.
Super....scr3wduh at the moment..gah
#133184 - 10/15/06 01:20 AM Re: FIRST RUN WITH THE 383
cleetus Offline
cleetus  Offline
NJ
If you can muster 101-102mph, you CAN hit high 12's.
79 Monte:383, XE294HR, Holley 700DP, Protopline 200cc aluminum heads, 4.10 8.5" posi, 700r4 w/3000ish stall--
12.04 @ 110.5. Crossing fingers for 11's.
#133185 - 10/15/06 02:10 AM Re: FIRST RUN WITH THE 383
Tallahassee
thats a bit more than 99 though heh, but hey lets see with real 60' ok?
#133186 - 10/15/06 04:32 AM Re: FIRST RUN WITH THE 383
MY FYN 79 Offline
MY FYN 79  Offline
N/E WI
Lowering your 60 ft times isnt nearly as beneficial for MPH as it is for ET. MPH may not change much, but getting better short times will get you some solid 13s for sure!
#133187 - 10/16/06 04:27 AM Re: FIRST RUN WITH THE 383
monte_man_79 Offline
somwhere in montana
high mph shows that the car is really making up all of it's time at the end of the track, and has a better ET to offer you if you get the 60 foot time down.. back when I had a 305 with 255/70r14s on with a mild cam/intake, I ran 14.5s @ 95 mph with 2.3 second 60 foot times. get some street slicks for it, and get it into the 13s!
what was your 660 ft time??? high 8s I hope?
79 Monte Carlo- 400 hp, 480 ft/lbs 406ci.
Monte carlo W/350 T-top-undergoing restoration
laugh "horsepower sells engines, torque wins races" laugh
#133188 - 10/16/06 04:31 PM Re: FIRST RUN WITH THE 383
Sparkee Offline
Sparkee  Offline
Central ILL
BTW, they do make 255/60R15 M/T ET Street Drag Radials.
http://www.mickeythompsontires.com/strip.php?item=ETStreetRadial
There is no such thing as too much horsepower, as long as you can put it to the ground!!
#133189 - 10/17/06 06:05 AM Re: FIRST RUN WITH THE 383
SMITHFOG Offline
SMITHFOG  Offline
SUN LAKES, ARIZONA
Sparkee - thanks for the thought. Any clue how much difference that 2 inch circumference would make? Would 275s be like going from 373 gears to 364?? (85/87x373=364)
#133190 - 10/17/06 06:29 AM Re: FIRST RUN WITH THE 383
SSMonte_Man125 Offline
San Tan Valley, AZ
i beleive you can go to a 275/55 tire and still have the same diameter it might even be a bit smaller
87' Monte Carlo SS vortec 350, VooDoo 437/454, 670 street avenger, HEI dist, AC/heater delete, Stock 373
13.3 @ 101 1.9 60ft-(garaged needs trans overhaul)
-07' Tahoe Z71
-12' Cruze 1.8l ecotec 6spd (gas sipper)
#133191 - 10/18/06 02:35 AM Re: FIRST RUN WITH THE 383
SMITHFOG Offline
SMITHFOG  Offline
SUN LAKES, ARIZONA
Where do you guys get your drag radials?
#133192 - 10/20/06 01:56 AM Re: FIRST RUN WITH THE 383
SSPARKY Offline
SSPARKY  Offline
Delavan Illinois
There is a guy on ebay (mccormack racing I think) has pretty good prices on M/Ts
7.88 @ 86.35mph
Take the Long Way Home
#133193 - 10/20/06 06:44 AM Re: FIRST RUN WITH THE 383
200kSS Offline
200kSS  Offline
Bloomsdale, MO
SMITHFOG: What cam are you running? Reason I ask is I just ran 13.43@101mph with 882 heads, xe274 cam and the same TH350/3000 stall/3.73 gears you have. Actually just sold some RPM heads too, kinda wish I had them back now. My 60ft time was 2.0 on a set of Hoosier Quick Times.
#133194 - 10/21/06 04:42 AM Re: FIRST RUN WITH THE 383
SMITHFOG Offline
SMITHFOG  Offline
SUN LAKES, ARIZONA
200kSS,
The cam is a mild Summit 1107
234/244 Duration
488/510 Lift
114 Seo
Pretty mild, but very streetable.
Next time motor comes apart, the cam will probably get replaced.
First project is new Mickey Thompson ET's I just ordered. I would be very pleased with a 2.0 60foot.
500/thumbs/Scott_s_88_SS_86_SS.jpg
by Scott_86SS
1166/thumbs/106681_0fe3b610bb_low_res.jpg
by lonk
500/thumbs/DSC03108-jpg.jpg
by f14dmechanic
500/thumbs/07-06-14_1759.jpg
by RoadWarrior
500/thumbs/IMG_1458.jpg
by Billdo38
