#1073501 - 03/24/22 06:56 PM
adding intermittent wipers
markg
nj
i have the cap with the electronics that goes on the motor. i also have an intermitent arm and swiitch for the column.is there anything else i need? is there a good writeup somewhere?
#1073504 - 03/25/22 01:31 PM
Re: adding intermittent wipers
[Re: markg]
AkronAero
Mark, I replace the motor/cap from another car and added the intermittent stalk and it worked fine. Didn't know you could just move the "electronic cap" over to the original motor? Let us know how that works out please. Gordon
#1073505 - 03/25/22 01:38 PM
[Re: markg]
markg
nj
thanks...im almost certain you can just put the cap on.how hard was it to put the new lever in? did the column have to come apart as much as fixing it when its loose?
#1073506 - 03/25/22 03:38 PM
[Re: markg]
AkronAero
I only recall it was easy... Nothing like column rebuild
#1073508 - 03/26/22 01:27 AM
[Re: markg]
IIRC, the switch is different as well!!
#1073510 - 03/26/22 06:31 AM
[Re: markg]
Honolulu
Interesting...I have the intermittent stalk but none of the intermittent features work. Possibly PO replaced with wrong motor???
1985 GMC Caballero 4.3L V6 TBI 200C w/ 2.41 peg leg 86 Monte Carlo SS BBC396 M20 w/ 3.42 posi screen name whip rust i.p.
#1073511 - 03/26/22 10:54 AM
[Re: markg]
markg
nj
the thing that the stalk clicks into is different.instead of having just 2 positions it has many little clicks for speeds.this is what i need ao swap out for the 2 speed one.
#1073515 - 03/27/22 01:03 AM
[Re: markg]
the thing that the stalk clicks into is different.instead of having just 2 positions it has many little clicks for speeds.this is what i need ao swap out for the 2 speed one. The wiper switch!!
#1073516 - 03/27/22 04:07 PM
[Re: markg]
69hurstolds
Aiken, SC
While the motors themselves (84-88) are the same, you can't just pop the pulse (CD4 RPO) cover on a non-pulse motor and magically have a pulse wiper motor. The wiper motor MUST have 2 contactors that plug into the park switch. GM p/n 22054236. They're basically flat bent metal with contactor "buttons" stamped into them that match up to the pulse cover contacts.
Also, the switch inside the column determines the pulse action, not the stalk itself. The stalk has NOTHING to do with pulse or non-pulse operation. They're interchangeable actually. Just the printing on the barrel is different.
So to have that pulse action for a non-pulse car, you would need to have a CD4 cover, the contacts, and the column pivot/switch part.
EDIT: I need to add that I did not research any electrical wiring differences with pulse or non-pulse, so it may or may not make any difference depending on that. But regardless, you'll still need the above mentioned items to successfully add pulse wipers to your non-pulse situation.
#1073517 - 03/27/22 06:29 PM
[Re: markg]
markg
nj
ahh yes...i remember putting a pulse cap on my non pulse motor once and it did not pulse.then somone told me about that contct thing you stated.i think i was able to take it off the old motor. inside the pulse cap there is a plastic arm.i was never sure of how to position it before reassembly but i dont think it matters.....thanks guys!
#1073521 - 03/28/22 02:44 PM
[Re: markg]
markg
nj
sweet....i found my spare intermittent cap and it has the 2 electrical connectors laying loose in it to make the connection with the non intermittent box. now the hard part. to put the pulse switch in the column. the rest is easy.
#1073745 - 04/27/22 08:41 PM
[Re: markg]
markg
nj
im just getting back to this now. i thought i had a wiper switch to put in but its a non pulse. i have a pulse one that i aquired from someone on the forum here but it looks different than the non pulse one i have here. i dont think its correct. these seem to be very expensive as well. is there a sourse for this thats not over a hundred bux?
#1073750 - 04/28/22 01:22 AM
[Re: markg]
the pulse and non pulse ones are different and if you look closely, wired different. Good luck!
#1074117 - 06/14/22 01:57 PM
[Re: markg]
markg
nj
does anyone know if this is the switch for a tilt column with intermittent wipers? i got this from someone on this forum a long time ago but cant find any info on it.it looks brand new.. Standard Ignition GM 26020404 Windshield Wiper Switch
#1074118 - 06/15/22 01:10 AM
[Re: markg]
I have a picture of the wiring part, let me see if I can add the pic? I can't get the picture to upload from my computer!!
#1074119 - 06/15/22 10:54 AM
[Re: markg]
markg
nj
thanks......very pricey online.it would be nice if this one i have will work.
#1074126 - 06/17/22 01:14 AM
[Re: markg]
Mark, send me a PM with a picture of your switch. It should have extra positions for the intermittent selections! Check that out!
#1074142 - 06/19/22 10:54 AM
[Re: markg]
69hurstolds
Aiken, SC
The correct GM part for pulse (intermittent) wiper switch for an 86 Monte Carlo with tilt wheel is 7843683, or aftermarket equivalent. Has 5 terminals IIRC.
That 26020404 swich is from an S-10 or van or something. Will it work? I dunno. It only has 3 terminals, and 2 more that are jumpered. I'm going to go out on a limb and say it's not going to work.
If you do not have tilt, the Monte Carlo NON-tilt pulse wiper switch is 7842716.
Standard DS-817 is the only equivalent aftermarket part for 7843683 that I'm aware of, and they're not cheap either. There may be others.
by Hot Rod SS
by CashMoneyMotorsports
by 87 SS 454
by SSexxymonte
by blkcharlotteman
