#1073454 - 03/15/22 01:45 PM
blower motor only works on low
markg
nj
this just happened yesterday.when i switch it to heat the motor spins on low but will not go higher when i move the switch to higher positions.i tried jiggling the wires around but it didnt change. any ideas on where to look? i know this has been covered before but my search on this forum is terrible. thanks
#1073460 - 03/16/22 10:30 AM
Re: blower motor only works on low
[Re: markg]
markg
nj
this morning even the lowest setting didnt work at all.i guess ill check the fuse first and then maybe try to hotwire the motor to see how it spins.the motor is from autozone but only a yr old.
#1073473 - 03/17/22 04:30 PM
[Re: markg]
markg
nj
i havent checked this yet but just to be clear once the slider is set to heat the fan is automatically on low speed right? if i have no power there then make sure the fan will spin and then check the fuse right.
#1073485 - 03/20/22 05:38 PM
[Re: markg]
AkronAero
Fan will run at low, M1, M2 or high depending on what you set fan switch for. If part of the resistor pack is burned out, for example, it may only work on low??? So you are sorting out: resistor pack, switch and/or relay? Gordon
#1073486 - 03/21/22 12:02 PM
[Re: markg]
markg
nj
the problem was very intermittent as i was checking everything. the motor spun fine if i hotwired it to the pos on the battery. on low it would only spin if i gave it a push.i got a new motor and it still wouldnt spin by itself without a push.med and high didnt work at all. the resistors seemed fine but the incoming voltages from the wires into it was screwey. i pulled the heater control from the dash and checked the fan switch which seemed fine and i just replaced it last yr.it started working after playin with it and i put it back. i moved the switch to med and hi and it wouldnt work again. it would up being the mode selector switch. its the only other electrical switch on the heater unit.luckilly i had a spare and its working properly now
by Hot Rod SS
by CashMoneyMotorsports
by 87 SS 454
by SSexxymonte
by blkcharlotteman
