#1072957 01/13/22 11:49 PM
IowanSS Offline OP
Ok sorry with all the questions. But now my blower motor don’t work. I put it on defrost high. Tested the fan. No power. Fuse looks good. Guessing relay. I just want some advise first. Then I noticed 2 vac line on the firewall. I do not remember where they hook up too. Can someone show me. Thanks.
IowanSS #1072958 01/14/22 02:08 AM
do you have power to the relay?
86ttop #1072962 01/14/22 09:53 PM
IowanSS Offline OP
There is no power at the relay.
IowanSS #1073027 01/22/22 08:58 PM
My manual says you should have battery voltage from the brown and white stripe wire with ignition switch to run, AC mode to vent and blower switch to HI.
This brown and white stripe wire runs behind the HVAC panel to the blower resistor where is becomes a solid brown wire.
IowanSS #1073563 04/04/22 11:35 PM
what year is this
