#1072849 01/03/22 07:59 PM
U
Ubowl Offline OP
U
Would anyone know what the fitting next to the distributor on the intake is for?it’s not the oil sender unit that’s on the side of the block This has a wire harness connector on it. Would appreciate it. Thanks John
Ubowl #1072850 01/03/22 08:01 PM
What year is your SS?
Ubowl #1072852 01/03/22 08:23 PM
U
Ubowl Offline OP
U
1988 SS 5.0
Ubowl #1072853 01/03/22 11:19 PM
Likely its the external ignition coil. 87 and 88 don't use coil in cap HEI.
Ubowl #1072857 01/04/22 02:10 AM
It's for coolant to circulate out of the rear of the head and into the heater hose to make sure that their are no air pockets. Is there a small hose connected to it or is it capped??
Ubowl #1072858 01/04/22 05:44 AM
Oil pressure switch for the choke???
1985 GMC Caballero 4.3L V6 TBI 200C w/ 2.41 posi
86ttop #1072859 01/04/22 06:55 AM
U
Ubowl Offline OP
U
There’s no hose nor place to attach one to
Buick Runner #1072860 01/04/22 06:58 AM
U
Ubowl Offline OP
U
The coil was bolted to the manifold. I changed the distributor to HEI type it had nothing to do with this item I’m referencing.
Ubowl #1072862 01/04/22 11:45 PM
Ubowl #1073567 04/04/22 11:44 PM
I think it is for the coolant dash gauge
Ubowl #1073571 04/05/22 07:06 PM
The only thing that I can think of in that area with a electrical connector on it and not associated with the distributor is the oil pressure switch. On Monte SS, it shares a circuit with the choke coil. Before I did my TPI conversion I had to determine what that circuit was for and if I needed it for TPI. The oil pressure switch there on the Monte prevents the electric choke from heating up with the key on-engine off. That way the electric choke only heats up when the engine is running.
87 SS, UMI trailing arms. Hooker 2050 Jet Hot Coated Headers. Hooker Cat-Back Exhaust, 350, Ported TPI, Trick Flow 56cc alum heads, SLP runners, Comp Cams 260AH-12, Trick Flow roller rockers, TCI 2400 stall converter, Denny's 3.5" Driveshaft, GBodyParts GNX Replica Rims 18x8 &18x9, F-Body Serpentine Belt Sys with Sanden A/C compressor mod.
1 members (Vincenti), 146 guests, and 11 robots.
Reggie0729, 86SS1982, rmw85, Tony Salazar, RevAl
16,051 Registered Users
