#1071749 - 08/22/21 06:16 PM Headlight harness
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
Okay all you electrical wizards with 85-87 MCs, I’ve got an identification question. I’m refurbishing my headlight harness and need a few wires identified. This is coming directly off the fuse block connector. There is a female four blade connector in the shape of an L with a yellow, dark green, pink and gray wire out of it. Second there is a female two blade connector that has the yellow from the four blade and a purple from the fuse block. Finally there is a single tan and white wire out of the fuse block. I need all three of these identified please.
I’m on my phone posting this so I can’t post a picture. If one is needed, I can post it later. By the way, if you’re following my build for Redline, it is finally at the paint shop!!! So things are getting a little closer! Thanks!!!!
1985 Monte Carlo SS
Under construction with a LS376 with a 4L70E
#1071765 - 08/23/21 01:16 PM Re: Headlight harness [Re: BoiseSS]
This manual is worth a million dollars when figuring out the wiring on a G-body. It's the best $10 investment you can ever make. I wore mine out when I was doing the LS swap.
You can get them on ebay. It says 1988 but it works for previous years as well.
https://www.factoryrepairmanuals.co...rical-diagnosis-service-manual-original/
671/thumbs/monte_001.jpg
by woodss
500/thumbs/090810_171838.jpg
by 87Aerocoupe87
500/thumbs/DSC020442.JPG
by javi05
500/thumbs/my_monte_3.jpg
by 85montanezcarloss
500/thumbs/white2.jpg
by go3and8
