#1070418 - 04/17/21 08:10 PM 8.8 FORD REAR DIFFERENTIAL
ohiomonte550 Offline
struthers, OH
i am thinking of using a rear that was given to me because i am concerned about strength, with that said i dont know for sure what it came out of told p71 cruiser but i have the numbers off the ring gear if anyone has any idea i would be thankful. ford ring gear number is- 3 355 FORD E7TW 1 39 9JC ANY HELP WOULD BE GREAT THANKS IN ADVANCE no tags and cant find anything on internet help
#1070431 - 04/19/21 12:44 AM Re: 8.8 FORD REAR DIFFERENTIAL [Re: ohiomonte550]
struthers, OH
(BUMP)
#1070432 - 04/19/21 01:01 PM Re: 8.8 FORD REAR DIFFERENTIAL [Re: ohiomonte550]
zelm86ss Offline
zelm86ss  Offline
Bremen,In
Is there any more numbers on the ring or pinion or do you have a tag from the axle housing that the gear came out of? I talked to our parts guys and the e7tw number would mean it was designed for a 1987 truck,but may have come out of anything else with a 8.8.
#1070434 - 04/19/21 02:07 PM Re: 8.8 FORD REAR DIFFERENTIAL [Re: ohiomonte550]
88ssBrent Online content
88ssBrent  Online Content
I have no info for you. I searched the info you gave above and came up empty handed. Hopefully someone can chime in.
#1070439 - 04/19/21 08:08 PM Re: 8.8 FORD REAR DIFFERENTIAL [Re: ohiomonte550]
struthers, OH
zelm 86 ss thanks i did some searching and 1987 is what i came up with as well and i know its a posi but i think its a 3.55 gear not a 3.73 like i was told and have to decide to shorten it to fit my monte or go with a 12 bolt, the price was right so im not complaining ill keep you updated and thanks brent and zelm for chiming in
#1070440 - 04/19/21 08:46 PM Re: 8.8 FORD REAR DIFFERENTIAL [Re: ohiomonte550]
zelm86ss Offline
zelm86ss  Offline
Bremen,In
No problem and good luck!
#1070441 - 04/19/21 09:15 PM Re: 8.8 FORD REAR DIFFERENTIAL [Re: ohiomonte550]
If it's really a 3.55:1 then it's only 5% taller than a 3.73:1. If a 3.73 is really ideal for your drivetrain, then a 3.55 probably won't make a significant difference. In almost all cases of sub-optimal alignments, think of the Taguchi loss function. HTH.
995/thumbs/44.jpg
by knight77
500/thumbs/monte_engine1.jpg
by 85lolo
1126/thumbs/1986_2.jpg
by Rich S
500/thumbs/009.jpg
by mdecker211
