#1069956 - 03/18/21 04:10 AM Steering column issues
Aroy Offline
Aroy  Offline
Grasswood, Saskatchewan
I bought an 86 monte carlo ss not knowing much about the history of the vehicle. It did not come with keys and the ignition was stuck in the auxiliary position and could only turn forward from there. Turning the ignition cylinder forward would only turn the power on and from there the previous owner had a push button start. I started with replacing to ignition cylinder but the cylinder still wouldn't turn to the off position. I then rotated the shift bowl on the steering column to the left and that allowed me to turn the ignition to off position and remove the keys. Now the steering wheel is locked and the ignition will not rotate in any direction.
If anyone has any knowledge as to what is should be tearing into next it would be greatly appreciated! The car has floor shift and is a tilt column
#1069957 - 03/18/21 04:32 AM Re: Steering column issues [Re: Aroy]
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
You know that the steering has steering lock, right? If not, did you try move the steering wheel and turn the key? You only have to move a little to turn the key.
#1069958 - 03/18/21 04:48 AM Re: Steering column issues [Re: Aroy]
Here's the best how to on a GM tilt steering column dissemble, repair and reassemble. Although a Fiero column all GM column are the same mechanically.
http://www.fiero.nl/forum/Forum2/HTML/088020.html
Page 3 and 4 are the how to.
#1069962 - 03/18/21 06:38 PM Re: Steering column issues [Re: Aroy]
You tube should have disassembly and repair instruction on the Saginaw column..Jeeps also had them. Many of these columns were easily busted into by car thieves who took advantage of the pot metal and plastic construction. Yours may have been damaged in a theft.
#1069966 - 03/19/21 01:08 AM Re: Steering column issues [Re: FinallySS]
The above should allow you to turn the key and start the car as normal!
#1070088 - 03/27/21 03:46 AM Re: Steering column issues [Re: FinallySS]
Aroy Offline
Aroy  Offline
That was the first thing I tried and no luck.
#1070856 - 05/25/21 10:25 PM Re: Steering column issues [Re: Aroy]
tom demarco Offline
tom demarco  Offline
Mooresville
check the rod that goes to ign switch and the switch he may had moved it
500/thumbs/My_Pictures00021.jpg
by 85MONTE!!
500/thumbs/IMG_1970.jpg
by Aeroaddict
500/thumbs/DCFC0005.JPG
by madmax74
500/thumbs/Monte_Carlo_3.jpg
by 468beast
702/thumbs/monteme1.jpg
by red/white04
