#1069816 - 03/09/21 06:02 PM Rough under load
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
Aloha guys.
As we speak, I am searching the web and see if I can find what I'm looking for but in the meantime, I thought I'll pick your brain(s) for a while.
Just yesterday, my SS was running beautifully. Problem started when I stumped on the gas to merge on the freeway. I took it up to maybe about 4500 rpm max (after about 3000 rpm, car trying to catch up or chase waaaaay behind me gave up. Kids nowadays never seen a old American car, so maybe they thought another grandma driving old American car?). After that acceleration, my car started to run really rough. Almost feel like it's starving for fuel as I give it a gas, still rough but gets little smooth and start to accelerate. For rest of the day, condition never improved but at any moment, idle is very smooth. No load rev, even when I give it a gas, will rev freely without any roughness. Fast forward it to today, cold engine just refused to accelerate. Still idles very smooth.
My combo for this engine is Eddy 600 carb (without choke), Summit 1102 cam (this one. https://www.summitracing.com/parts/sum-1102/make/chevrolet), Summit valve spring kit (https://www.summitracing.com/parts/sum-174000), Mid-length header (I know it's Hooker, but don't have the part # as it came with the car. Full headers in near future), El-cheapo Chinese dizzy (adjustable advance vacuum can), Accel 8.8 wires (need to change soon), Brand new Spark plugs (I think it was ND Iridium. Just wanted to try out something. Since it's new, I have no plan to change it any time soon), Summit ignition box (https://www.summitracing.com/parts/sum-850610), 1-inch carb spacer (Can't remember if it was square to Q-jet or just square, but it's open spacer), K&N filter and full dual exhaust (no cat. Don't blame me. Car came that way!).
Now, when I came home, I checked that, timing is OK (initial 12 degree, hooked up to manifold vacuum), Plugs were all OK (no excessive carbon build up. I'm still playing with carb jetting), made sure step-up piston is not stuck (moved freely in the bore), Accel. pump function (it shoots fuel), look into carb bore making sure nothing is in there (had filter on, so unlikely but just to make sure) and making sure carb received the fuel it need (pump is working but I do not have pressure gauge at the moment). I do not have any method of checking the plug wires so left it alone for now. I'm planning to take the carb off in a few hours and give it a good cleaning by disassembling it. I do not have rebuild kit in hand and will be using old gasket until it gets here (It is on the way. Order it last night just in case). I just hope that weather stay clear of rain (it's very dark and cloudy right now).
Now, for what I done recently is I removed the intake because it had oil leak from back of the intake (I didn't put enough RTV last time I had it apart) and while I'm at it, took both cylinder head off and changed the valve springs. I did adjust the preload on lifters, but I'll gonna do it again just in case if cleaning the carb won't change anything. No vacuum line to check other than the line going to vacuum can on dizzy and to the vacuum ball. Both checked out fine as I have vacuum pump with gauge on it (cheap one, but it'll do the job for now).
Anything I'm missing? Any suggestion? My DD is still in repair (waiting on one rear wheel bearing I bought back in 2/21/21. According to USPS tracking, it made it to CA on 2/25/21, and it move from there on 3/1/21 as it said still in transit, but I still haven't receive it yet. USPS said because of the snow storm you guys suffered, but in CA? To this day, I'm still waiting for it.......................) so I need my SS going again.
#1069820 - 03/09/21 07:39 PM Re: Rough under load [Re: FinallySS]
Mine ran like this after sitting for 6 yrs after my initial stock restoration. Turned out the fuel line from the tank was plugged/clogged with stale gas fuzz. I think you answered your question, sounds like fuel starvation.
#1069821 - 03/09/21 09:10 PM Re: Rough under load [Re: FinallySS]
88ssBrent Online content
88ssBrent  Online Content
Mine had the same symptoms. It drove me crazy. It ended up being the fuel filter clogged. Of course mine is the factory quadrajet. Changed the fuel filter at carb and everything was fine.
#1069823 - 03/09/21 11:27 PM Re: Rough under load [Re: FinallySS]
AkronAero Offline
AkronAero  Offline
Or check for failed or cracked dist cap or shifted ign?
#1069825 - 03/10/21 06:57 AM Re: Rough under load [Re: FinallySS]
My tractor does this once a year when the needle valve from the previous year begins to stick and strave the engine at wide throttle.
#1069826 - 03/10/21 07:22 AM Re: Rough under load [Re: FinallySS]
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
Thanks for all the advice guys.
Finished cleaning the carb, look at the plugs, check ignition wires for physical damage and all the other stuff. Because of the weather, couldn't do much and I'm all tired. test drove it up and down the driveway ramp and the roughness went away. Will drive it to work tomorrow and see how it goes. Couldn't find any obstruction while cleaning carb, but shot all the passage with either carb cleaner or Brakleen (used both. carb cleaner ran out), so hopefully, if there was any obstruction, it did clear it away.
#1069837 - 03/10/21 05:00 PM Re: Rough under load [Re: FinallySS]
I'd suggest some SeaFoam as well, it might get a few more places than the carb cleaner did. It would also keep whatever was gummed up from gumming up again if you use it periodically.
#1069847 - 03/11/21 03:53 AM Re: Rough under load [Re: FinallySS]
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
Thanks hunter for the advice. I'll grab some when I have a chance. Long overdue, in my opinion.
Yup. Runs way better than what it was, but still not the way it was running. One thing I forgot to check is fuel filter, so I'll definitely check first chance I got (raining outside now).
Maybe something got loose and clogging the fuel system. I need one whole clear day...................
500/thumbs/IMG_0697.JPG
by 565bbchevy
1083/thumbs/0221111610.jpg
by PIMPC3692
500/thumbs/seat_001.JPG
by montec_ss85
650/thumbs/DSC01290.JPG
by monte_kev
