#1069310 - 01/19/21 10:09 PM 9" Differential Brand Opinions
Wilson Offline
Wilson  Offline
Brighton il
Since I cannot find a 8.5 differential, I am looking to build a 9". Many different builders Moser being the most popular. Strange builds a really nice piece with some added expense. Quick Performance is about the most economical. Has anyone used their brand of axles? Looking for some options. Thanks
#1069314 - 01/20/21 03:39 PM Re: 9" Differential Brand Opinions [Re: Wilson]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Why not a 12 bolt? Keep it GM.
#1069315 - 01/20/21 04:07 PM Re: 9" Differential Brand Opinions [Re: Wilson]
I have run a quick performance 9" for at least 10 years. As with everything else, it's kind of you get what you pay for. IF you are willing to work on and fix a few of the QP's low spots, it's a better economical choice. The hgiher end Strange, Moser, etc housings are nicer and more complete...but that comes with a price.
What I found when shopping for an upgrade mainly hinged upon brake choice. The Ford Explorer rear disc kit that can come with the QP 9 is a fantastic economical brake upgrade while disc brake choices for the 12 bolt tend to be a bit more spendy.
#1069331 - 01/22/21 05:51 AM Re: 9" Differential Brand Opinions [Re: Wilson]
jmireles Online content
jmireles  Online Content
El Paso, Tx
I also have a QP 9" with disk brakes. I had to have custom parking brake cables built.
in '08. 3K
#1069336 - 01/22/21 07:45 PM Re: 9" Differential Brand Opinions [Re: Wilson]
MAP Online content
MAP  Online Content
Hi Wilson - I think we need to stop fixating on ring gear diameter and look at pinion gear diameter instead. The latter overwhelms the former in terms of stress imparted to the teeth. Beyond that, bearings and metallurgy. Beyond that, brakes, etc.
A 2.19:1 rear might work fine with a 7.5" OE ring gear, for example. But 4.11:1 will require a more expensive solution and a big ring gear.
I know that's not much help but it's all I've got - apologies. I had a GN 3.42:1 8.5" rear that gave zero trouble, but that's just anecdotal data.
Best - MAP
#1069337 - 01/23/21 04:11 PM Re: 9" Differential Brand Opinions [Re: Wilson]
Wilson Offline
Wilson  Offline
Brighton il
Correct. That is why I am looking into replacing it with a 9 inch.
If I could find a 8.5 I go that route. They are really scarce anymore.
#1069343 - 01/24/21 06:44 PM Re: 9" Differential Brand Opinions [Re: Wilson]
200kSS Offline
200kSS  Offline
Bloomsdale, MO
Try pemracing.com
I just got this one: https://www.shoppemracing.com/product-p/stfhnm290290-tt.htm
Add your own brake kit or use their's.
#1069352 - 01/25/21 02:38 PM Re: 9" Differential Brand Opinions [Re: Wilson]
No problems with my QP 9". As mentioned in another thread, I had to clock the Explorer calipers at 4 o'clock to clear the frame. Long parking brake cables wrap around the top of the axles. Changing the proportioning valve to run rear discs was a knucklebuster.
#1069417 - 02/01/21 05:45 AM Re: 9" Differential Brand Opinions [Re: Wilson]
El Paso, Tx
I'd like to see pictures of your set up, Upflying.
in '08. 3K
#1069422 - 02/01/21 03:35 PM Re: 9" Differential Brand Opinions [Re: Wilson]
I wish I knew how to post pics, past attempts was a struggle and I failed. I guess I'll have to revisit the photo hosting process.
Other forums have a little paperclip thingy that makes posting photos easy.
#1069432 - 02/02/21 05:28 AM Re: 9" Differential Brand Opinions [Re: Wilson]
El Paso, Tx
I was warned about the frame making contact with the calipers but I didn't clock them differently and yes, I've had issues....it also doesn't help any that QP didn't add bump stops. I've yet to remove them from the stock diff and weld them on or possibly source them elsewhere.
in '08. 3K
#1069571 - 02/15/21 01:33 PM Re: 9" Differential Brand Opinions [Re: Wilson]
Wilson Offline
Wilson  Offline
Brighton il
Anothe question would be rear brakes. I know disc brakes are the hot setup but are they worth the headache over drums? Wilwood vs other brands?
If I were to go to wilwood or another brand then have to replace the fronts. Sigh!!!
#1069573 - 02/15/21 11:11 PM Re: 9" Differential Brand Opinions [Re: Wilson]
the_merv Offline
the_merv  Offline
Northern, Florida
I have been running a 9" for over 10 years.
Quick Performance Housing, Moser 31 Spline Axles, Strange S Case, Detroit TruTrac Diff, Richmond 3.89 Gears, Aluminum Daytona Pinion Support with 1350 Chromeoly Yoke. LT1 Fbody Rear Disc Brakes on it. I prefer Discs because they are simple.
1984 MONTE CARLO SS 6spd
#1069574 - 02/16/21 12:22 AM Re: 9" Differential Brand Opinions [Re: Wilson]
Wilson Offline
Wilson  Offline
Brighton il
That is the exact same setup gear ratio case and trutrac that i have ordered. Haven't ordered housing yet deciding what brake setup going with yet.
665/thumbs/GUAGES.JPG
by MOSTWANTED
500/thumbs/Monte_Teardown_030.jpg
by kpetry
1096/thumbs/photo_17_.JPG
by 83/84/86*2/87ss
500/thumbs/ss_at_dyno1_small_file.jpg
by kahlua1836
by ray396
