#1069204 - 01/13/21 09:20 PM Disc Brake conversion
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
Quick question. If I'm converting the rear to disc and I have the Disc/Disc proportioning valve, do I still need a Disc/Disc master cylinder?
1985 Monte Carlo SS
Under construction with a LS376 with a 4L70E
#1069209 - 01/13/21 10:59 PM Re: Disc Brake conversion [Re: BoiseSS]
I'd guess that having a matched master/prop valve/caliper volume "fully engineered" would be best and will get the most out of the system, but I think there's hundreds of guys who have seen a good improvement switching to rear discs and just doing the prop valve... Some folks much smarter than me might have a different take, but I don't think you "Have to" switch by any means. And it might depend on which rear brakes you are using as well.
#1069222 - 01/14/21 05:58 AM Re: Disc Brake conversion [Re: BoiseSS]
jons86 Offline
jons86  Offline
greensboro,nc
There many options, I want to do this soon too, Im thinking 8.8 w manual adj proportial vlv. Check utube
#1069223 - 01/14/21 05:59 AM Re: Disc Brake conversion [Re: BoiseSS]
jons86 Offline
jons86  Offline
greensboro,nc
#1069250 - 01/15/21 06:59 PM Re: Disc Brake conversion [Re: BoiseSS]
malibudave78 Offline
Houston, TX
Usually, you have to upsize the master cylinder depending on what master cylinder you are using.
1978-1981 "g-bodies" have 24mm strait bore master cylinders used with the factory power booster.
1982-1988 g-bodies have step bore master cylinders with a larger bore 1.25+" for volume that necks down inside the bore to a smaller 24mm for higher line pressures.
If you have the step bore master cylinder, it may work fine depending on what rear caliper you run.
If you go with fairly large rear calipers, you will most likely need to upsize your master cylinder to a 1.0" bore master cylinder.
What rear caliper are you plan on using?
#1069251 - 01/15/21 08:58 PM Re: Disc Brake conversion [Re: malibudave78]
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
I'm getting a Currie crate 12 bolt rear end with Ford 11" disc set up on it. The set set up is a Ford Explorer rear disc. Not sure on the specs. Since they're an OEM set up, I think I'll be fine with the stock Master. Thoughts?
1985 Monte Carlo SS
#1069254 - 01/16/21 02:44 AM Re: Disc Brake conversion [Re: BoiseSS]
You'll need a disc/disc master cylinder and appropriate combo valve. Good luck!
500/thumbs/DSC02786.JPG
by Joe87monteSS
500/thumbs/moto_0058.jpg
by dw329
by 1NJIMID8TOR
500/thumbs/Mighty13w7.jpg
by bumpn1ohm
