#1069119 - 01/07/21 03:49 PM 1988 Monte Carlo SS
David7357 Offline
David7357  Offline
Lawrenceburg, IN
Runs great for about one hour .Then it quits and won't start sounds and act like it out of time. Then it sits for a few hours and then it starts and runs great. Only has 41,000 miles on it. Need any help.
#1069120 - 01/07/21 03:54 PM Re: 1988 Monte Carlo SS [Re: David7357]
88ssBrent Online content
88ssBrent  Online Content
Everything original? 305/2004r? Any trouble codes or dash lights on?
#1069121 - 01/07/21 04:41 PM Re: 1988 Monte Carlo SS [Re: David7357]
David7357 Offline
David7357  Offline
Lawrenceburg, IN
Everything original no codes. 305
#1069122 - 01/07/21 05:06 PM Re: 1988 Monte Carlo SS [Re: David7357]
I don't want to tell you wrong so I will wait for others to come in. It might take a little while, forum doesn't get much traffic but when it does lots of people that are knowledgeable. If it was a code I might be able to help. Going off what you said above first thing I would look at is the coil but might be a complete dead end.
#1069123 - 01/07/21 05:18 PM Re: 1988 Monte Carlo SS [Re: David7357]
David7357 Offline
David7357  Offline
Lawrenceburg, IN
Thanks I appreciate it.
#1069126 - 01/07/21 07:28 PM Re: 1988 Monte Carlo SS [Re: David7357]
zelm86ss Offline
zelm86ss  Offline
Bremen,In
Does the car have spark and fuel when it doesn't start? If no spark,I would guess the pickup in the distributor. My 86 has a module and pickup,but the 88 system is a little different due to having a external coil. I've had some other cars ( not Monte Carlos) that had the same symptom as you and it was the stator (pickup) in the distributor. If it was my 86,I'd start with a module and stator,but first you should do some diag. On a car with a external coil (a two wire coil),a test light can be used to verify a good stator. One side should be hot and the other should pulse during crank. If the pulsing side is erratic,i'd guess a bad stator (pickup). Being a 1988 I think those had a external coil and not a internal one like my car.
#1069128 - 01/08/21 12:10 AM Re: 1988 Monte Carlo SS [Re: David7357]
David7357 Offline
David7357  Offline
Lawrenceburg, IN
Thanks we found out the the distributor had a crack and the rotor button was bad. Thanks guys really appreciated the help.
#1069129 - 01/08/21 02:05 AM Re: 1988 Monte Carlo SS [Re: David7357]
Welcome to the BEST site on the net. Has the car ever had a complete tune up, plugs, wires, cap and rotor, along with the gas filter in the carb?? Now would be a good time to take care of the rest of the work. Good luck!!
500/thumbs/IMG_0697.JPG
by 565bbchevy
1083/thumbs/0221111610.jpg
by PIMPC3692
500/thumbs/seat_001.JPG
by montec_ss85
650/thumbs/DSC01290.JPG
by monte_kev
