#1067930 - 09/12/20 06:05 AM Help with Code 12
felkermick Offline
felkermick  Offline
Warsaw IN
I recently purchased a 1986 SS that has 9800 miles on it and was well taken care of. When I purchased this Monte it had the check engine light on, and I jumped out AB pins and constantly got a 1 flash followed by 2 flashes over and over again. I looked that code up and it says basically there are no stored codes on my car, yet the check engine light is on. Car seems to run fine when driving and idling(sometimes dies when idling when stopped and in drive rpm drop below 300 when hot). I removed the negative battery cable lead for about a min or two and that did not clear the service engine soon light. My car has a few upgrades, it looks like it has electronic distributor and Edelbrock 4 barrel carb. Other than that she is stock. I can't seem to figure out what could be causing the Service Engine Light (Code 12). Again I let it blink when I jumped AB for over 2 min and it only ever blinked the code 12. Thanks for any help here.
#1067931 - 09/12/20 03:06 PM Re: Help with Code 12 [Re: felkermick]
Doylestown, PA
Welcome to the forum.
It's going to flash code 12 three times, then any actual codes that are stored. Each code will flash 3 times, then code 12 will repeat at the end of the readout.
I can tell you right now that your light is on because of the Edelbrock and possibly the distributor if it's not the stock one. These cars came with a computer-controlled distributor and computer-controlled quadra-jet carb. If either of those are removed, it basically breaks the CCC system. What you do next will depend on what direction you want to go with the car. If it's truly 9800 miles, you may want to keep it original. In that case I would suggest reverting to a stock CCC carb/distributor. If you prefer, you can remove the CCC system and emissions components completely, depending on how concerned you are with local legal requirements for inspection, etc... If you choose to go that route, you will lose transmission converter lockup unless you install a kit to replace that functionality.
~ Matt H.
#1067932 - 09/12/20 03:18 PM Re: Help with Code 12 [Re: felkermick]
If there is no check engine light on the code 12 means there is communication with the diagnostic port and since there are no other codes, all is well.
If the check engine light is on and all you get is a code 12 that means there is a communication problem with the computer. It could be a number of things, including up to a bad ECM. In your case since the computer carb has been replaced with a Edelbrock there's no feed from the computer carb and possibly they disconnected all the computer controlled wiring under the hood.
Does it have a vacuum advance "pod" on the distributor or is it a full electronic distributor? If it doesn't have a vacuum advanced distributor and still has the stock computer controlled distributor, it will go into limp home mode. If so, that's why it dies at times - the only amount of timing you have with the computer controlled distributor is the base timing - typically 6-10 degrees when everything is working, but they may have jacked the base timing up enough so it'll run.
Let us know which distributor you have and whether or not the computer controlled carb came with the car when you bought it.
Edit - started typing before Matt's response - lol
#1067933 - 09/12/20 03:35 PM Re: Help with Code 12 [Re: felkermick]
Pretty simple, the Eddy carb is not compatible with car as it lacks computer provisions like every aftermarket carb and is not an upgrade over the factory E4ME Quadrajet carburetor. The stock carburetor has a air fuel mixture control solenoid and a throttle position sensor, which every aftermarket carb lacks. The factory computer system is all or nothing, remove any part and it goes into limp mode.
This is a common problems with G bodies, a previous owner hacks up the car and then sells the basketcase to an unsuspecting buyer. Even if you replace the carb with a correct factory one, there may be other strange modifications and Jerry rigging that will need to be repaired correctly. There is not much we can help you with over the net as it would take a expert to look over the car in person to see if there are any more Jerry rigging in the car. We can't examine the car over the net. Normal idle RPM is 2,200 cold, 600 hot in gear, 300 is way too low.
#1067937 - 09/12/20 10:55 PM Re: Help with Code 12 [Re: felkermick]
88ssBrent Online content
88ssBrent  Online Content
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=245007#Post245007
I feel that this link would be a good place to start for the problems your having. You are just going to have to make the decision if you want to go back to stock feed back carb or move forward with doing away with everything. Like stated above its all or nothing.
I really like the ccc system. I deal with programmable logic control (plc) on a daily basis so I find the ccc very interesting as it a lot alike (the inputs, the computer (brain), and outputs). I can only imagine at the time how excited g.m. engineers were when they created it in its infancy.
With that said, I'm sure at some point I will get away from it because it does have some limitations.
If I were in your shoes I would probably go the route I posted above and do away with the system. I think it would be the easier route without knowing what is there and what is not and what all has been done by previous owner. Good luck.
#1067941 - 09/13/20 12:28 AM Re: Help with Code 12 [Re: 88ssBrent]
felkermick Offline
felkermick  Offline
Warsaw IN
I'm gonna see what a local repair shop thinks ... they are pretty good working on older vehicles. I'll forward this info to them and drop off my car see what exactly was done by the previous owner. I may go back to the Quadrajet carb as I'd rather be stock in the 1st place. Thanks for information it's gonn take a few weeks I think to get car into shop and figure out what changes were made here.
#1067945 - 09/13/20 01:08 AM Re: Help with Code 12 [Re: felkermick]
86ttop Online grandpa
86ttop  Online Grandpa
the stock quadrajet carb part number stamped vertically on the drivers side is 17086003, good luck!!
#1067948 - 09/13/20 03:24 AM Re: Help with Code 12 [Re: felkermick]
84LS1T56SS Offline
84LS1T56SS  Offline
Central, Arkansas
There just happens to be a NOS carb on ebay right now.
500/thumbs/MC_lowered.jpg
by tunit
by blkcharlotteman
by PoorBoysRacing
1084/thumbs/1318197026021.jpg
by 87SSon6s
500/thumbs/IMG_1195resize.jpg
by monte_mike
