#1067832 - 09/02/20 04:39 AM
Aerocoupe fire damage restoration
AeroSS_87
Lincoln, NE
Alright, let's get this party started.February, 1987, my parents received their special ordered Aerocoupe. I remember vividly walked up to it with plastic on the seats, window sticker, everything. Grew up in the car from age 6 til present. For high school graduation in 1998, I was blessed to take ownership of the car. June, 1999, an electrical short sent it up in flames. Here we are in this foul year, 2020, and it's time for my 40 year old butt to get in gear. Here is the car being dug out from where it was buried behind a boat, motorcycles, etc, for 21 years. ![[Linked Image]](https://i.ibb.co/t4DwBT9/20200607-101816-01.jpg) Here is a 3-fold of a Colorado trip in 1987, me with the car in February of 1999, and current year after being dug out with my ugly mug next to it. ![[Linked Image]](https://i.ibb.co/HV2hS6T/Polish-20200611-204631196.jpg) Let's get this thing home! ![[Linked Image]](https://i.ibb.co/CM4K79Z/20200607-131138.jpg) ![[Linked Image]](https://i.ibb.co/wYGY2Dd/20200607-134611.jpg) The third generation of this car, and its future owner. ![[Linked Image]](https://i.ibb.co/KXMGLYf/20200829-152414-01.jpg) First up, get 21 years of crap off of it. I used a foam cannon with 3x the appropriate dose of Chemical Guys foam solution, applied twice, followed by two hand wash over the good areas. ![[Linked Image]](https://i.ibb.co/Trt0rJc/Polish-20200607-204111912.jpg) Now, the hair-standing part - getting the window out safely, and retaining the seal. After a few calls and subtle interrogation, I found just the guy. ![[Linked Image]](https://i.ibb.co/r2Hyxcx/20200615-102031.jpg) ![[Linked Image]](https://i.ibb.co/9cW5j8p/20200615-102234-01.jpg) Success! ![[Linked Image]](https://i.ibb.co/K6jWv7T/20200615-141354.jpg) ![[Linked Image]](https://i.ibb.co/3MGTFtp/20200615-111157-01-01.jpg) Thank God, these are in reproduction now.. ![[Linked Image]](https://i.ibb.co/xscmYyR/20200615-104337.jpg) Third brake light was a little damaged, so I gave it a little restoration of its own. ![[Linked Image]](https://i.ibb.co/PGgJPQF/Polish-20200619-003143319.jpg)
#1067870 - 09/07/20 01:21 PM
Re: Aerocoupe fire damage restoration
[Re: AeroSS_87]
upflying
Looking forward to watching the restoration. Are you going to buy a rusty but stock and original parts car for the rebuild? BTW, if I had to guess, the fire started in the HVAC electrical bundle behind the dash. When I was rebuilding my car, I found several burned, melted and smoked wires attached to the HVAC control panel. My car almost went up in smoke...before I owned it.
#1067907 - 09/10/20 04:31 AM
[Re: upflying]
AeroSS_87
Lincoln, NE
Good luck. Ive been wanting to do a repaint on mine but that rear glass is just so intimidating. Don't be intimidated by the glass seal. It's really goopy, but not bad. Just do your research in finding the right glass guy. And if someone approaches the seal from the outside with a Sawzall, boot them to the curb before they start. Looking forward to watching the restoration. Are you going to buy a rusty but stock and original parts car for the rebuild? BTW, if I had to guess, the fire started in the HVAC electrical bundle behind the dash. When I was rebuilding my car, I found several burned, melted and smoked wires attached to the HVAC control panel. My car almost went up in smoke...before I owned it. It actually started somewhere between the battery and starter, but I can't figure out even still how it happened. I remember when it started, I saw coolant leaking and the positive cable sparking on the ground from the starter post. The quality of a donor to build off of will be determined by t what's available in the coming months. Ideally, a well kept, 100k-ish mile example. Pulling the engine and trans this weekend and hauling to the storage unit till I can find the right car.
#1067913 - 09/10/20 04:32 PM
[Re: AeroSS_87]
PB86SS/87LS
Administrator 20+ Year
Great pics to start off, look forward to seeing it move forward! At least door back the parts look generally usable or even very nice.
#1068067 - 09/21/20 04:39 AM
[Re: AeroSS_87]
AeroSS_87
Lincoln, NE
1 gallon of denatured alcohol, 33 razor blades, and a whole lot of patience later, the sacred window is cleaned up 🙏🏻 Before ![[Linked Image]](https://i.ibb.co/RDB3hdD/Screenshot-20200920-235409-Quick-Pic.jpg) After ![[Linked Image]](https://i.ibb.co/9tQnNDZ/20200920-233612.jpg)
Moderated by 345HP87SSAC, 85_SS, Dalt10, Gruvin, mannblk, MC87SS, mcss383, MY FYN 79, Phil87SS, Russ, ss4ever, Z65_Paul
by Gbodss
by Mando/88SS454
by 02intimidator
by AndreB
by McNamee
