#1067781 - 08/26/20 07:52 PM Bake lines, master cyl, rear hose assy.
8T7AERO Offline
8T7AERO  Offline
Corona, CA
HI I have multiple questions, 1st question the rear brake lines that go to the rear wheel cylinders are they single or double flare ? I'm converting to disc and have to cut them. 2nd what is the bore size of the master cylinder 1" or 1-1/8 ? 3rd does anybody know where to purchase the rear hose assy from the cross member to the brake lines on the differential ? Mine is ok but since i have everything apart, might as well change it. Thanks
#1067782 - 08/26/20 08:04 PM Re: Bake lines, master cyl, rear hose assy. [Re: 8T7AERO]
I believe everything should be double flared, and the secondary MS bore is 36mm or 1.42 inches.
#1067787 - 08/27/20 01:01 AM Re: Bake lines, master cyl, rear hose assy. [Re: 8T7AERO]
You can get that rubber hose at any good parts store, I use and recommend NAPA, good luck!!
#1067803 - 08/28/20 06:22 PM Re: Bake lines, master cyl, rear hose assy. [Re: 86ttop]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
Thanks again for the info everyone and @86ttop, pick it up yesterday from NAPA online with a 20% discount Thanks
#1067810 - 08/29/20 01:04 AM Re: Bake lines, master cyl, rear hose assy. [Re: 8T7AERO]
thumbs
#1067829 - 09/01/20 05:52 PM Re: Bake lines, master cyl, rear hose assy. [Re: 8T7AERO]
malibudave78 Offline
Houston, TX
Rear line is an inverted, double flare.
Stock master cylinder is a step bore. The primary bore is 24mm for both front and rear brakes. The seconary bore is 36mm, like stated above, and is only used on the front brakes, but it transitions down to the smaller 24mm primary bore for higher line pressures. I am not sure of the rear calipers you are using, but you can go to a 2000 right hand drive S10 master cylinder if you are using stock rear disc calipers. It is a 1.0" strait bore and is a bolt on and should work well with rear calipers. You might have to replace your front calipers if they have never been changed out as they are low drag and need a step bore master cylinder to work correctly. Any stock replacement caliper should be a normal, NON low drag caliper.
RAYBESTOS MC390572
Link to master cylinder swap: https://maliburacing.com/forum/threads/new-master-cylinder-option.124945/
You should be able to get the rear rubber line that is over the axle from the auto parts store.
#1067852 - 09/04/20 09:11 PM Re: Bake lines, master cyl, rear hose assy. [Re: malibudave78]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
David thanks for the info: the front are the Wilwood DynoPro 6 piston calipers 120-13428/29 and the backs are the Wilwood 4-piston C6 calipers 120-13916. I'm upgrading the brakes and the suspension system and was wondering about upgrading the master cylinder as well. Keith
#1067869 - 09/07/20 12:30 PM Re: Bake lines, master cyl, rear hose assy. [Re: 8T7AERO]
Houston, TX
The Wilwood Front front calipers have a slightly smaller piston area than the twin piston S10 Blazer caliper.
The Wilwood rear calipers have a smaller piston area than a S10 blazer rear caliper.
That being said, the Right Hand Drive, 1.0" bore S10 master cylinder still would be a good fit if your vacuum brake booster is in good working order, but if your stock master cylinder is in good working order, I would try it first and see how you like it with the Wilwood brake setup. The smaller bore of the stock master cylinder MAY make your brakes a little more touchy with less brake feel, but you can't tell 100% unless you try it.
For any good brake setup, buy the stickiest tires you can afford to take advantage of your brakes.
#1067874 - 09/07/20 03:31 PM Re: Bake lines, master cyl, rear hose assy. [Re: 8T7AERO]
BladeOfAnduril27 Offline
Doylestown, PA
Thanks for the link about that master cylinder. I'm replacing my stock one and the blazer MC looks like a good choice since I'm already running Blazer front brakes and probably going to Blazer rear disc at some point. Unfortunately it looks like the ACDelco part is discontinued. I could not find it in stock anywhere. Raybestos MC390572 seems to be the same master, so I ordered that from RockAuto last night.
~ Matt H.
500/thumbs/IM001255_2_.JPG
by ProchargedMonteSS
500/thumbs/IMG_0251_2.jpg
by DannyB
500/thumbs/IMG_0693.JPG
by 565bbchevy
500/thumbs/IMG_0395s.jpg
by Turbo5
by SickSpeedMonte
