#1066941 - 06/22/20 05:33 AM 4 center gauges not working
Trey Offline
Trey  Offline
Cullman Al
Ok so my parents gave me their 86 ss, it sat for ywars and has along way to go to be back to its former glory but i have one major issue. Rats chewed some wires for the headlight switch. I got those fixed but my temp, volts, oil, and fuel gauges dont work. Tach works, but has been off bad for years,and speedo works. What us really strange tho is when turning lights on, the twmp hand shoots up to 260. The other 3 dont do anything. I have the cluster pulled and the radio/climate control but cant see any other wires damaged. Any ideas on what i should be looking for or where to look? This is the main hold up on getting the ss back on the road
#1066964 - 06/23/20 01:12 AM Re: 4 center gauges not working [Re: Trey]
As these cars age and the plastic warps from the heat, the gauges can be very finicky. It sounds to me like partly a ground problem and poor connections at the gauge plug in behind the dash. You could try to release the plug from the dash and plug it in to the cluster and see if that helps. Good luck!!
#1067005 - 06/25/20 05:18 PM Re: 4 center gauges not working [Re: Trey]
Trey Offline
Trey  Offline
Cullman Al
Ive got the cluster out and had tried replugging it but still nothing. Will check the actual contacts and everything when i go to the shop in a lil while just to see if there is any visible damage. The car has 144xxx miles on it so its not stupid high miles but could be enough to cause issues. For the most part the car is in good shape other than rust damage.
Where would i begin to look for grounds for the cluster by chance?
#1067222 - 07/10/20 03:58 PM Re: 4 center gauges not working [Re: Trey]
tom demarco Offline
tom demarco  Offline
Burlington
plastic circuit board, or connection at lower right corner, you can check for ground at that connecter where pins rub plastic circuit board
#1067243 - 07/12/20 04:20 AM Re: 4 center gauges not working [Re: Trey]
This may help you, pinout for the cluster plug.
http://www.chevyasylum.com/tech/pinout.html
#1067501 - 08/03/20 03:42 AM Re: 4 center gauges not working [Re: Trey]
tom demarco Offline
tom demarco  Offline
Burlington
push on right lower corner of instrument panelwith key on push then relax push then relax see if needles move
737/thumbs/small_DSC00316.jpg
by McNamee
500/thumbs/MCSS4.jpg
by Wrathchild
500/thumbs/SD530544.JPG
by pearl83SS
500/thumbs/87_Monte2.jpg
by mightymonte10
500/thumbs/Photo_4.JPG
by Chief Jimbo
