#1066281 - 05/02/20 11:36 PM Reverse lights.
David Offline
David  Offline
Rochester,NY,14615
Mine have always been sporadic depending on where I leave the shift......Today they were not on at all.
Is this a common problem? Easy fix?
#1066282 - 05/03/20 01:14 AM Re: Reverse lights. [Re: David]
they are controlled by the NSS, down on the column,it can be adjusted and you'll probably need a helper to observe the backup lights as you adjust the switch, or it may need to be replaced. Good luck
#1066295 - 05/04/20 04:54 PM Re: Reverse lights. [Re: David]
Hunter79764 Online content
Hunter79764  Online Content
Mine is a column shift, and has always been touchy but holding the shifter closer to Park keeps them working. I adjusted once shortly after I got it, but they would come on in neutral and not always in reverse, so I adjusted back a little and ended up in the same place as it was initially. So I got lazy and decided to live with it...
500/thumbs/003.JPG
by SSPARKY
500/thumbs/DSC00188.JPG
by 3rdHorseman
500/thumbs/IMG_1460.jpg
by Billdo38
500/thumbs/DSC02318.JPG
by Driven_88
848/thumbs/DSC04966.JPG
by bnelson85ss
