#1065562 - 03/19/20 06:44 PM Grand National Rear End ID
8T7AERO Offline
8T7AERO  Offline
Corona, CA
Hi does anybody know how to ID a GN rear end. Thanks
87 Aerocoupe,Rapp Racing 383.Leather interior. headers, flowmasters, k&n filter,MSD Ing, 17x8 iroc w/ 245/45/17 s.s.b.c.calipers & cross drilled rotors. Kenwood sound system..
#1065572 - 03/20/20 03:02 AM Re: Grand National Rear End ID [Re: 8T7AERO]
You mean specifically a rear end from a Turbo Regal, or any g-body 8.5”?
Here are links to help in either case(7.5 vs 8.5 pics courtesy of me 20 years ago, 8.5” is no longer silver):
https://gbodyforum.com/threads/how-to-determine-your-rear-end-type.18581/
http://www.gnttype.org/numbers/axcodes.html
#1065585 - 03/20/20 06:10 PM Re: Grand National Rear End ID [Re: PB86SS/87LS]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
Thanks for the info:, The reason is I picked up 8.5 posi 4.11 ratio that's been gone through for cheap and was told it was out of a GN.The casting marks are on it are 14075742, GM1 and what looks like either I047 or 1047 . Just wanted to check if it was a GN 8.5.
#1065601 - 03/21/20 04:43 AM Re: Grand National Rear End ID [Re: 8T7AERO]
There will be numbers and letters about 3/8" tall stamped into the front face of the right tube on the rear. These tell what the rear was installed in, here's a GN list.
https://buickturboregal.com/rear-axle-codes-turbo-buick-regal/
Also only the G-body used that stupid three bolt (backing plate/ anchor bolt) flange at the tube ends.
The two ears at 5 and 7 o'clock and that number cast into the centersection, 14075742, would indicate an 8 1/2 but not necessarily a G-body 8 1/2".
500/thumbs/1986montels3.jpg
by mj86lsmonte
500/thumbs/Side1.jpg
by RocknSS
500/thumbs/Upholstry_5.jpg
by Scott_86SS
799/thumbs/carlos4.jpg
by Frenzy
500/thumbs/02Big.jpg
by SickSpeedMonte
