#1065280 - 03/05/20 03:56 PM USB conversion
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Hello: has anyone converted the cigarette lighter adapter to a USB port? If so, please advise...thanks
#1065293 - 03/06/20 12:51 PM Re: USB conversion [Re: MisterAdam]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
I have not done it, but think it could be easily done with something like this:
That one is just a charging port.
Link: Amazon USB charging port
#1065307 - 03/06/20 11:57 PM Re: USB conversion [Re: MisterAdam]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Thanks....would it connect to the battery?
#1065309 - 03/07/20 02:18 AM Re: USB conversion [Re: MisterAdam]
Or at the starter post where the battery cable connects, ground doesn't really matter as long as it's clean and tight, Good luck!!
#1065328 - 03/09/20 12:02 AM Re: USB conversion [Re: MisterAdam]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
I'd run it to the fuse box & connect it to a fused circuit.
#1065344 - 03/09/20 06:17 PM Re: USB conversion [Re: MisterAdam]
If you are installing it directly in place of the cig lighter, you could clip those wires and use them (unless the car is otherwise clean enough to keep it all "Factory").
500/thumbs/IMG_0028.JPG
by mikem
500/thumbs/IMG_1164resize.jpg
by monte_mike
500/thumbs/montess1.jpg
by MaverickMonte85
527/thumbs/88SS_ChopFour.jpg
500/thumbs/IMG00190-20101225-1712.jpg
by terryrh85
