#1064327 - 11/30/19 03:39 AM Loose sun visor
Nadnerb42780 Offline
Rockland County, NY
The sun visor on my 86 SS is loose and falls down little by little after each bump I hit in the road until it is all the way down. Does anybody know the easiest fix?
#1064328 - 11/30/19 03:47 AM Re: Loose sun visor [Re: Nadnerb42780]
there is a screw that you can tighten? Have you had the sunvisor off the mount that attaches to the ceiling?? Coupe or TTop??
#1064331 - 12/01/19 12:54 AM Re: Loose sun visor [Re: 86ttop]
Rockland County, NY
It is a t top. The fabric on the visors were just replaced along with the headliner, so yes the visor was removed a few weeks ago. Didn’t want to mess with anything and make it worse. Thanks for any input.
#1064372 - 12/05/19 10:14 PM Re: Loose sun visor [Re: Nadnerb42780]
T5montecarlo Offline
Lederach, PA
I have the same issue in my 1986. The screw for the clamp in the visor is tight. The problem is the stud spins in the visor bracket. I replaced one of them, now the other one is loose.
#1064456 - 12/15/19 04:28 AM Re: Loose sun visor [Re: Nadnerb42780]
RoadWarrior Offline
RoadWarrior  Offline
Mechanicsburg, Pa
Here's the fix. https://gbodyparts.com/visor-swivel...?osCsid=c200d72126480244e86911089d0cd480
Remove screw, slide off visor, install clip, reinstall visor, reinstall screw, visor will/should now be tight
MadMax
88 SS, 355 owned since '03
#1064483 - 12/16/19 06:36 AM Re: Loose sun visor [Re: Nadnerb42780]
Z65_Paul Offline
Z65_Paul  Offline
McDade, TX
Thanks for that link Jon. At $2 a piece, that's a great solution. The order form said due to the size of the order (small) they would calculate shipping and contact me with a separate charge. Unfortunately their cart system wants to charge $17 minimum for shipping. I couldn't see any way to not get charged that, so cancelled the order.
PaulC
#1064489 - 12/17/19 02:11 AM Re: Loose sun visor [Re: Nadnerb42780]
If you take that bushing picture to a good hardware store, I'll bet you can find a substitute, good luck!
#1064507 - 12/18/19 05:10 AM Re: Loose sun visor [Re: Nadnerb42780]
RoadWarrior Offline
RoadWarrior  Offline
Mechanicsburg, Pa
Wow, yeah my standard shipping comes up at 12.99, I know when I ordered my set it was with other items. I think they're the standard standard for gm vehicles listing 65-81, you can even find them on Amazon, summit..etc
MadMax
#1064508 - 12/18/19 06:26 AM Re: Loose sun visor [Re: Nadnerb42780]
Z65_Paul Offline
Z65_Paul  Offline
McDade, TX
Found them on ebay easily for a reasonable price, including the grommets with free shipping. $14.99 (plus tax) for two bushings and two grommets.
thumbs
#1064522 - 12/19/19 01:57 AM Re: Loose sun visor [Re: Nadnerb42780]
thumbs
500/thumbs/1287432657916.jpg
by Aaron88SS
500/thumbs/racecar1.jpg
by Wisconsin
500/thumbs/002.JPG
by SSPARKY
500/thumbs/juangomez22_SS.JPG
by juangomez22
500/thumbs/2011-10-04_18_51_24.jpg
by Lonniegee
