#1064147 - 11/14/19 05:03 PM High Cruising RPM
jmireles Offline
jmireles  Offline
El Paso, Tx
So I feel the engine in my Monte is turning over too quickly for the speed I'm cruising at. So let's say I'm driving at 70 MPH, the RPM gauge reads around 3K. I have a completely stock LS2/4L65e out of an '06 GTO and a 9" with 3.70 gears. It has a .69:1 overdrive gear. I double checked the RPM gauge by connecting a scanner and it is within 100 RPM of the gauge. Does that sound right??
I have a '77 Trans Am with a Pontiac 467/TH400 with 3.23 gears that will show around 2.5K on the RPM gauge at the same speed. The turbo 400 has a 3rd gear with 1:1.
Any insight is appreciated.
in '08. 3K
#1064148 - 11/14/19 05:31 PM Re: High Cruising RPM [Re: jmireles]
What's the tire size?
#1064149 - 11/14/19 05:57 PM Re: High Cruising RPM [Re: jmireles]
jmireles Offline
jmireles  Offline
El Paso, Tx
Yeah, I forgot that.
Monte has 215/60-15
Trans Am has 245/60-15
I think they both have a 27in. tall tire.
in '08. 3K
#1064150 - 11/14/19 06:00 PM Re: High Cruising RPM [Re: jmireles]
jmireles Offline
jmireles  Offline
El Paso, Tx
I was off by a bit...25 in. tires.
in '08. 3K
#1064151 - 11/14/19 06:04 PM Re: High Cruising RPM [Re: jmireles]
Very good calculator to check the numbers.
#1064153 - 11/14/19 07:11 PM Re: High Cruising RPM [Re: jmireles]
Seems like you should be closer to 2500 @70 in OD, and if it wasn't going into 4th but rather staying in 3rd, it should be around 3500. Do you have a loose converter that might not be locking up? I'd expect a couple hundred RPM rise with no lockup engaged, maybe more if it has some stall to it...
#1064158 - 11/15/19 04:40 AM Re: High Cruising RPM [Re: jmireles]
It's been a long time since I ran a lock-up transmission in the Monte and have never run a 4l65e. Best I remember the rpm difference between being locked and unlocked was around 100 maybe 150 rpm (???) increase/decrease, Tomorrow if I can remember I'll check to see what the difference is in the 6L80e in the G8.
However, I did have a friend with a 4l65e that was slipping about 800 rpm in high gear when his torque converter clutch wasn't engaging and the tran temps increased significantly. When you drive it again, get up to about 60mph keep your foot at the same position on the throttle and use your left foot to barely press the brake pedal to check to see if there is a change in RPM. If not your lockup isn't engaging and could be increasing the temp high enough to get a good bit of slippage. Best I remember my buddy had a wiring issue and a fluid pressure issue causing his excessive increase in RPM/slippage problem.
Hope that helps in some way.
#1064162 - 11/15/19 02:03 PM Re: High Cruising RPM [Re: jmireles]
I'm at 2500 rpm at 70 mph.
I am using this to control my 4L65E.
https://www.gmperformancemotor.com/parts/19302405.html
#1064171 - 11/16/19 06:21 PM Re: High Cruising RPM [Re: jmireles]
jmireles Offline
jmireles  Offline
El Paso, Tx
Upflying,
Didn’t you LS swap your Monte too? Why do you need a controller for the transmission if the PCM is running things?
in '08. 3K
#1064173 - 11/16/19 08:24 PM Re: High Cruising RPM [Re: jmireles]
Originally Posted by jmireles
Upflying,
Good question, my LS3/4L65E swap is a Connect and Cruise from GM Performance..it included the trans controller and the PCM as a complete plug and play package. The installation instructions were detailed and required the installation of the controller. I wasn't aware the PCM could control the transmission without the trans controller..
This is what I purchased and installed, you can see the trans controller in the photo.
https://www.chevrolet.com/performance/connect-cruise-powertrain-systems
#1064177 - 11/18/19 05:52 AM Re: High Cruising RPM [Re: BadSS]
jmireles Offline
jmireles  Offline
El Paso, Tx
I finally had some time to drive the Monte around today and performed this test. The RPM did slightly change...it rose about 200 or so RPM. So I guess the converter is locking up?
in '08. 3K
#1064178 - 11/18/19 02:04 PM Re: High Cruising RPM [Re: jmireles]
Sounds like it is working, so it rules that out.
#1064183 - 11/19/19 12:31 AM Re: High Cruising RPM [Re: jmireles]
T5montecarlo Offline
Lederach, PA
But if the converter was locked, there would be no change in rpm if the speed did not change.
At 70 mph, he is turning 2500 rpm. At 60 mph, he would be turning 2142 rpm ((60x2500)/70). An increase of 200 rpm increase would be approximately an increase of 5.6 mph if the converter is locked up. If the car speed did not increase by 5-6 mph, the converter is not locking up.
Marc
#1064184 - 11/19/19 12:42 AM Re: High Cruising RPM [Re: jmireles]
Oh, you stick shift guys. Locking or unlocking the converter makes no difference in mph. The rpm only changes because the converter is slipping when unlocked. Same thing as slipping the clutch at 60 a little bit,
#1064185 - 11/19/19 01:22 AM Re: High Cruising RPM [Re: jmireles]
Lederach, PA
OK, brain fart occurred. When pressing the brake, the converter will unlock, so a failed test. The same test should be tried without pressing on the brake. If the rpm flare, the converter is not locked.
Marc
500/thumbs/1986montels3.jpg
by mj86lsmonte
500/thumbs/Side1.jpg
by RocknSS
500/thumbs/Upholstry_5.jpg
by Scott_86SS
799/thumbs/carlos4.jpg
by Frenzy
500/thumbs/02Big.jpg
by SickSpeedMonte
