#1063748 - 10/10/19 09:12 PM Under good lamp and switch?
Will87SS Offline
Will87SS  Offline
Bristow, Va
My under hood lamp is not hooked up. Just a female blade connecter laying loose. I can’t find a switch anywhere. Where does that normally reside? Or where should I look for the male end?
#1063749 - 10/10/19 09:23 PM Re: Under good lamp and switch? [Re: Will87SS]
AkronAero Online content
AkronAero  Online Content
You have the fixture clipped to the hood it appears. It uses one hot wire from firewall and when the hood is opened, the liquid mercury switch closes sending power through the bulb to ground. Similar to trunk light.
#1063784 - 10/15/19 10:15 PM Re: Under good lamp and switch? [Re: Will87SS]
axld Offline
axld  Offline
lakeland,fl
look under the wiper motor bracket area.
500/thumbs/tail_end_hitch_has_to_go.jpg
by AndreB
568/thumbs/badbattz.jpg
by battz89
506/thumbs/100_0568.JPG
by 85_SS
500/thumbs/20200422_222519.jpg
by Rodney
500/thumbs/photo_4_.jpg
by itslvbaby4
