#1062967 - 07/30/19 01:02 PM a/c compressor decision time.
MarauderPrime Offline
Melbourne, Florida
Hey Guys, I just discovered that the original (from 1984) R4 compressor on my monte has given up the ghost. I am planning on doing either an LS swap, or moving forward with modernizing the 350 thats in it (Now that we are applying modern tech to the old SBC, it looks like the power difference between them is only like 15% if you do things well on your small block, and the gap closes even more when boost comes into the equation), but either way, I am planning on running an R4 compressor with either setup.
Either path I chose would require me to convert the pulley over to the camaro/b-body style 6 rib, from the V-belt. How hard is that to do? I had been told in the past that its do-able, but that the cost of the new clutch and pulley itself is so close that you might as well just buy a new compressor for that application instead of swapping out the pulley, and I really don't want to buy a compressor twice. So if its not worth it to swap the pulley, I may just garage the car until November, and then do the compressor when I do whatever motor stuff I am going to do.
84 Monte Carlo SS 454, 4L80E, 8.5" 3.42 Posi Rear, Full Sequential EFI , Comp XM284HR, Comp 26120 Beehive Valvesprings, Titanium Retainers, Doug's G-body 2.25" Primary Longtube Headers, Siemens Deka 80Lb. Light Blue Injectors, Edelbrock 1000 CFM throttlebody P/N 4150, Kwik Performance GM Truck SBC conversion brackets. Howell EFI Harness and Tune.
#1062970 - 07/30/19 05:35 PM Re: a/c compressor decision time. [Re: MarauderPrime]
If you are going to do the compressor pulley switch, you'll have to change other pulleys as well, you might as well do the complete conversion to a serp setup, but if you are really planning on an LS Swap, that compressor is different. Either way, it won't be cheap to do! On the other hand, there is a better compressor than the R4 to use as a replacement compressor, I do not have the particulars on that compressor, others here may have that info for you. Good luck. As a Florida resident myself, I would not go without A/C in the summer!!
#1062971 - 07/30/19 07:36 PM Re: a/c compressor decision time. [Re: MarauderPrime]
Somewhere in my feeble memory I recall reading about a G-body friendly serpentine pulley swap involving the use of '95 and older Chevy truck TBI 350. Parts you need could be a close as your wrecking yard.
I could be wrong so I'm not sure.
#1062999 - 08/02/19 02:13 AM Re: a/c compressor decision time. [Re: MarauderPrime]
jmireles Offline
jmireles  Offline
El Paso, Tx
I think you can also use the accessory brackets from a late 3rd Gen F-body...they also used the R4 A/C compressor. I think if you did that, you'd be better off getting a Regal condenser, so that the compressor and condenser service ports are both on the passenger side.
in '08. 3K
#1063240 - 08/20/19 10:17 PM Re: a/c compressor decision time. [Re: MarauderPrime]
Huskerfan Offline
Huskerfan  Offline
Omaha Ne
Talking about air conditioning does anyone know where to but the lines unfortunately when i bought my car it was already taken off. Also the line that runs across the fan shroud is that part of the air conditioning system? Thanks
#1063242 - 08/21/19 01:30 AM Re: a/c compressor decision time. [Re: MarauderPrime]
Jeff, I bought mine at NAPA, didn't need the hard line. If you can't get them at NAPA, try www.mikesmontes.com and good luck!!
#1063283 - 08/23/19 02:45 AM Re: a/c compressor decision time. [Re: 86ttop]
Huskerfan Offline
Huskerfan  Offline
Omaha Ne
Thanks Alot I will check into it.
500/thumbs/front_seat1.jpg
by Rodney
1113/thumbs/BadAssFender7.jpg
by upflying
by MaverickMonte85
1125/thumbs/IMG_5004.jpg
by The PC Surgeon
