#1062925 - 07/28/19 12:29 AM What cam are you running on your 305 L69?
Supa.Slo.SS Offline
Supa.Slo.SS  Offline
Rancho Cucamonga CA
I am looking for cheap HP for my SS. I have purchased a set of Edelbrock TES headers and Edelbrock 3701 Intake for pennies on the dollar and would like to find a good cam to seal the deal. This is going to be a weekend cruiser but would like enough under the hood in case I need to put a Honda its place, hahaha. It's an 84 SS entirely stock with exception of the headers and intake I will be installing as soon as I am done resealing the motor.
PS.. I am trying to not put too much money into this engine as the ultimate plan is to do an LS swap which I already have from a personal car that was totaled.
#1062926 - 07/28/19 12:58 AM Re: What cam are you running on your 305 L69? [Re: Supa.Slo.SS]
Travis Jones Online headbang2
Just save for the LS swap.
That's my advice.
#1062932 - 07/28/19 02:19 AM Re: What cam are you running on your 305 L69? [Re: Supa.Slo.SS]
B5tmike Offline
B5tmike  Offline
Waynesburg OH
i run the same intake and headers with a crane 114122 with 1.6 rockers. that combo really woke up my L69
#1062933 - 07/28/19 04:00 AM Re: What cam are you running on your 305 L69? [Re: Supa.Slo.SS]
I use a Crane Cams 2040 EmissionMax cam with TES headers, ZZ4 intake, and a ZZ4 PROM.
LS swaps in CA are tricky because of the utra strict emission laws there and the fact the enhanced OBD2 EVAP doesn't work with stock G body gas tanks that are non enhanced. Basically, the only legal LS swap in CA are the expensive GM Erod LS crate kits with the special legal swap parts and paperwork which used junker engines lack. Probably better off selling the used LS and use the money towards a crate.
#1062937 - 07/28/19 02:36 PM Re: What cam are you running on your 305 L69? [Re: B5tmike]
Huskerfan Offline
Huskerfan  Offline
Omaha Ne
Hows the idle with that cam?
#1062939 - 07/28/19 03:06 PM Re: What cam are you running on your 305 L69? [Re: Supa.Slo.SS]
My idle is still smooth.
#1062941 - 07/28/19 03:52 PM Re: What cam are you running on your 305 L69? [Re: B5tmike]
Supa.Slo.SS Offline
Supa.Slo.SS  Offline
Rancho Cucamonga CA
Did you keep the original springs and lifters? I was between that cam and the next one up in size, part number 114142 grind 2050.
#1062942 - 07/28/19 05:40 PM Re: What cam are you running on your 305 L69? [Re: Supa.Slo.SS]
The cam included new lifters which I used, I reused the stock springs through I really should upgrade them.
#1062943 - 07/28/19 07:40 PM Re: What cam are you running on your 305 L69? [Re: Supa.Slo.SS]
88ss408 Offline
88ss408  Offline
miramichi, NB
I had a xe262 in a 305 ho 700r4 SS and it ran great. Had long tubes duals performer airgap and reworked Qjet and HEI.
Then I eventually swapped to a 600 eddy.
1988 monte carlo ss 408 sbc
1984 monte carlo cs 400 sbc
500/thumbs/003.JPG
by SSPARKY
500/thumbs/DSC00188.JPG
by 3rdHorseman
500/thumbs/IMG_1460.jpg
by Billdo38
500/thumbs/DSC02318.JPG
by Driven_88
848/thumbs/DSC04966.JPG
by bnelson85ss
