#1062526 - 06/26/19 03:08 PM Borgeson 800 Steering Box
While this isn't a 670, it's their own design, and It's good.
https://www.summitracing.com/parts/brg-800130/overview/year/1986/make/chevrolet/model/monte-carlo
Great on center feel, I've been chasing this for years!
Apparently Borgeson got tired of trying to chase 670 cores and made their own design. I installed it last night and I am very happy with it.
I wasn't prepared to drop $700-$1000 on a 670 box and this one fit the bill price wise and performance wise.
I'm doing a full writeup on this for Summit on their OnAllCylinders Blog.
#1062527 - 06/26/19 06:09 PM Re: Borgeson 800 Steering Box [Re: Travis Jones]
MC96 Offline
MC96  Offline
St. Johns MI
It looks like a copy of a 600 series case, I wonder why they decided to call it an 800?
Maybe people hear 600 and think of the junk old 605? I would guess that they still source the input cover from GM or its suppliers rather than making it from scratch
86 SS
In progress
#1062541 - 06/27/19 02:47 PM Re: Borgeson 800 Steering Box [Re: Travis Jones]
86aerocoupe87 Offline
Massillon, Ohio
I just installed one in my 77 Cutlass before the Hot Rod Power Tour. A great improvement over stock. I found it not as stiff as the Monte Carlos which took some getting used to as it's easy to overcorrect.
86 Aerocoupe
#1062543 - 06/27/19 03:06 PM Re: Borgeson 800 Steering Box [Re: 86aerocoupe87]
Yes, I agree it does seem to have a little lighter feel to it, but then again I am running an LS style truck power steering pump which is the highest pressure and volume pump that GM ever made, I installed a few extra shims on the flow control valve to turn the pressure down, but i think that it's the higher volume that causes the over-boosted feel.
#1062771 - 07/17/19 09:52 PM Re: Borgeson 800 Steering Box [Re: Travis Jones]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Travis, thanks for the info. I've been looking to replace my steering box for some time now without having to spend $800. I'm curious how do you get to the pressure regulator in the power steering pump?
#1062775 - 07/18/19 01:28 PM Re: Borgeson 800 Steering Box [Re: Fred SS]
Hi Fred, I made a write up on this topic, but until Summit gets around to publishing it I cant share it publicly. However, if you want send me a PM and I'll get you an advanced copy to review,
However most of what you are looking for is here https://static.summitracing.com/global/images/instructions/brg-899001.pdf
So I did go back and put more shims on, I used 4 shims in total, and once I feel like dealing with the PS mess again, I may try out 5 shims to see if its an improvement. I don't know with a stock Monte SS pump if you's need to adjust the pump output pressure, Overall with 4 shims I like the steering feel, tight on center, which is what I was after... but ill be honest, there isn't too much road feel in it, which may be the result of either my alignment or 60 year old steering geometry... I did talk to to borgeson about using a flow reducer, and they shot the idea down, as rapid steering input changes (like autocross) could cause the box to starve for fluid and act all herky-jerky.
#1062776 - 07/18/19 01:31 PM Re: Borgeson 800 Steering Box [Re: Travis Jones]
Is there any danger with having the "overboosted" setup, other than the feel? (Or lack thereof?)
I've been running mine with the truck pump and stock (non-SS) box for 8 years but only about 20k miles, most of it highway. Just wondering if I'm risking blowing out something in the box with too high of pressure, or just making it feel like a granny car (which is fine with me, honestly).
#1062777 - 07/18/19 01:35 PM Re: Borgeson 800 Steering Box [Re: Hunter79764]
Nope, no danger at all the burst pressure on your lines is like 10k psi or something silly.
#1062782 - 07/18/19 09:22 PM Re: Borgeson 800 Steering Box [Re: Travis Jones]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Thanks for the offer Travis. I did find allot of info on the web after googling it. Anyway, on my setup I'm using a stock SS steering box with a F-Body power steering pump. I installed an F-body serpentine belt system so I used the F-body pump. I heard that the F-body pump has higher pressure than the stock Monte SS pump. I do get a jerky feeling in the steering wheel when parking. I'm not sure if that is caused by too low pressure or too high.
#1062791 - 07/19/19 03:47 AM Re: Borgeson 800 Steering Box [Re: Travis Jones]
Fred here's a write I did 20 years ago on the G and F pumps. A lot has changed since then.
Way back then the XH box was installed in my car with the stock pump. Did those valve mods to improve the feel. Installed a Borgeson shaft. About 8 years ago rebuilt the XH box, seals, still running the stock G pump with those mods today along with the XH box. I would have a hard time spending all that money to buy the Delphi box.
Some reading:
http://jeffd.50megs.com/Pump_valve_mod_page.htm
http://jimshea.corvettefaq.com/wp-c...teering-Pump-Pressure-Flows-09OC2013.pdf
#1062795 - 07/19/19 03:12 PM Re: Borgeson 800 Steering Box [Re: Travis Jones]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Thanks Bob. I'll definetly read those articles.
Travis, thanks for pointing me in the direction of the Borgensen power steering flow valve kit.
Fred
#1064168 - 11/16/19 12:25 PM Re: Borgeson 800 Steering Box [Re: Travis Jones]
axld Offline
axld  Offline
lakeland,fl
i also am in need of a box change( I did a swap 8 years ago , box was from one of those corner auto parts store) . i feel like a cup driver sea-sawing driving down the road, lol. But i also have a hydro boost system ( from Hydra-Tech) and the corvette pump ( 2.4/2.8 GPM @from 1250/1350 PSI ) . Any body else with this combo using the 800130 box? I am not afraid to spend the money if there is a BIG difference in the performance. I already have a billion dollars in this car according to the wife !
#1064332 - 12/01/19 02:00 PM Re: Borgeson 800 Steering Box [Re: Travis Jones]
chevelle502 Offline
chevelle502  Offline
Dundalk. MD
Doing my suspension build this winter and steering is next up, glad I popped back in. This thread is awesome! Thanks for sharing.
Black w/T-tops
500/thumbs/Wrangler_SS_1.JPG
by WranglerSS
1129/thumbs/72.JPG
by GBODY88
500/thumbs/IMG_1186.JPG
by PB86SS/87LS
500/thumbs/100_1275.jpg
by RocknSS
500/thumbs/Scott_s_88_SS_before_paint.jpg
by Scott_86SS
