#1061992 - 05/22/19 08:38 AM Pinion angle
345HP87SSAC Offline
345HP87SSAC  Offline
Stanberry, MO
Those with aftermarket rears what are you setting the pinion angle at? I need to do that on my aerobafter the rear swap.
#1061993 - 05/22/19 01:03 PM Re: Pinion angle [Re: 345HP87SSAC]
SSLance Online content
SSLance  Online Content
Set it parallel to the trans output shaft. My trans is 3.5 degrees down so my pinion is 3.5 degrees up.
#1062001 - 05/22/19 11:48 PM Re: Pinion angle [Re: 345HP87SSAC]
345HP87SSAC Offline
345HP87SSAC  Offline
Stanberry, MO
Thanks Lance! 3 degrees was coming to mind. I don't have a gauge, but I will figure it out.
#1062006 - 05/23/19 03:18 AM Re: Pinion angle [Re: 345HP87SSAC]
MC96 Offline
MC96  Offline
St. Johns MI
Iphones have a level in either the compass or measurements app depending on what iOS you have
86 SS
In progress
#1062012 - 05/23/19 04:15 PM Re: Pinion angle [Re: 345HP87SSAC]
Harbor Freight has a nice digital one for like $10-15
#1062015 - 05/23/19 07:28 PM Re: Pinion angle [Re: 345HP87SSAC]
345HP87SSAC Offline
345HP87SSAC  Offline
Stanberry, MO
Harbor freight here I come. If not I will try my phone! It is an I8.
#1062021 - 05/24/19 04:03 PM Re: Pinion angle [Re: 345HP87SSAC]
Tremec Tool Box in Apple app store
#1062071 - 05/29/19 03:03 AM Re: Pinion angle [Re: FrankOC]
mrengineer Offline
mrengineer  Offline
The D, MI
That is a great app. Driveline angle finder, vehicle speed, RPM, and tire size calculator as well. Driveline angle is easy to use and accurate.
Mr. Engineer
#1062115 - 06/01/19 07:41 PM Re: Pinion angle [Re: 345HP87SSAC]
Hi Folks,
About the pinion angle, please remember that it varies as a function of suspension loading, and as a function of the torsional compliance created by the suspension bushings reacting to the driveshaft torque. Since you have no choice but to use a single setting, try to optimize for an average loading condition for which you want to minimize vibration.
HTH,
500/thumbs/IMG_0697.JPG
by 565bbchevy
1083/thumbs/0221111610.jpg
by PIMPC3692
500/thumbs/seat_001.JPG
by montec_ss85
650/thumbs/DSC01290.JPG
by monte_kev
