#1061564 - 04/17/19 09:39 PM Glove box cable location ?
monte 5 Offline
monte 5  Offline
new york
Hi guys !.. my glove box cable broke a while back, half of the old one is still attached to the box, I since had the dashboard redone. I have a new cable on the way, can someone help me and post a pic where the other side attaches to the dash and how. Thanks !!!
#1061572 - 04/18/19 04:03 PM Re: Glove box cable location ? [Re: monte 5]
monte 5 Offline
monte 5  Offline
new york
Problem Fixed !
#1064210 - 11/21/19 02:58 AM Re: Glove box cable location ? [Re: monte 5]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Can u send me a pic..I have the same issue..thanks
#1064213 - 11/21/19 01:23 PM Re: Glove box cable location ? [Re: monte 5]
T5montecarlo Offline
Lederach, PA
I have my dash out. Here is a picture from the backside of the dash showing where the cable attaches.
#1064215 - 11/21/19 03:41 PM Re: Glove box cable location ? [Re: monte 5]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Excellent Thanks!!! I couldnt figure out where that small cable went
#1064222 - 11/21/19 06:42 PM Re: Glove box cable location ? [Re: T5montecarlo]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Did you notice a thin black wire when you removed the glove box? I notice mine while I was trying to figure out the glove box cable. Im not sure where it goes; its just there....any help will be appreciated. thanks
#1064223 - 11/21/19 06:55 PM Re: Glove box cable location ? [Re: monte 5]
Lederach, PA
In my car, the only wires I saw were the one in the picture to restrain the glove box, one for the lamp, and two for the trunk release.
There are also some black ground wires at the right side of the lower dash that bolted to the bracket that the dash mounts to.
I just looked at the picture of my interior with the dash removed, and there are no other loose wires; all are bundled.
Have you checked to see if it is a ground? or if it has power with the ignition on or off?
Marc
#1064237 - 11/22/19 06:02 PM Re: Glove box cable location ? [Re: T5montecarlo]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
I havent done either. I just noticed it. It could be a ground wire that has came a loose. I appreciate your input and suggestions...
#1064251 - 11/23/19 02:32 AM Re: Glove box cable location ? [Re: monte 5]
Mister Adam, the ground wires are at each end of the dash where it bolts to the vehicle, do check there because there is more that one ground wire at each end, good luck!!
#1064254 - 11/23/19 03:34 AM Re: Glove box cable location ? [Re: 86ttop]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
thanks. I will
827/thumbs/88_MONTE_454R_BIG_BLOCK_SS_.jpg
by Mando/88SS454
500/thumbs/motorpic2.JPG
by GearedSS
500/thumbs/l_5e2d157f59c84c07f4636b01b201dd32.jpg
by Chappell86
500/thumbs/mc53.jpg
by McCall72
500/thumbs/05-01-08_1754.jpg
by Gbodss
