#1059289 - 10/04/18 01:54 AM
Re: Brake Issue, Need Answers
[Re: mikester]
Are the rear brakes adjusted properly??
#1059293 - 10/04/18 01:47 PM
[Re: mikester]
Travis Jones
If you're gonna go through all that trouble.. why not run discs?
#1059522 - 10/21/18 01:20 PM
[Re: mikester]
84ss355*4spd
Edmonton,AB,Canada
Did you bench bleed the master cylinder before putting it in the car? Has to be bench bled . Hope that helps.or there is a small leak somewhere not noticed . Good luck
84ss current restoration 86 ss gone 85 ss new 85 z28 tpi ![[Linked Image]](http://i447.photobucket.com/albums/qq200/_monte_man_/mathewscarpics024-1.jpg) ![[Linked Image]](http://i19.photobucket.com/albums/b164/majestic_11/meandthemonte-2.jpg)
#1059530 - 10/22/18 01:40 AM
[Re: mikester]
A bigger bore M/C is incorrect, you need to go back to the original size wheel cylinders!
by ray396
by stevec_87SS
by Witman69
by donzss
by TriumphoverU
