#1058953 - 09/04/18 11:20 PM Transmission pan leak
WaSSted Offline
WaSSted  Offline
Kennewick
It's been years since I've posted but I'm at the end of my rope with my car. I might put 500 miles a year on it. Anyway 3 months ago I changed the pan gasket cause I got tired of the leak. I cleaned everything. Made sure the stock pan sealing surface was as flat as possible. I used a felpro gasket and tightened in an alternating pattern to I think 12 ft lbs. Drove it and double checked the pan bolts, then parked it.
So it has been sitting all summer. I checked it every month and no leaks, until just recently (last weekend). I don't understand how it leaks when I don't even drive it.
Cork gasket? Silicone? What do I need to do to get this thing to stop? I've been told to get that $250 aluminum pan. But why can't I get the stock pan to seal?
Please help
Kirk Herres
#1058957 - 09/05/18 01:15 AM Re: Transmission pan leak [Re: WaSSted]
When a vehicle sits a lot, the torque converter drains out, you may have a leak at the TV cable exit point or possibly the fill tube connection, check out these possibilities!
#1058965 - 09/05/18 01:34 PM Re: Transmission pan leak [Re: WaSSted]
Agree with Leo, those two points are possible leaks to check.
Had similar problem with friends Bowtie Overdrive 200 R, gasket leak. We swapped in my old 200 R pan and fixed problem.
With pan tightening I loosely snug the bolts and then go around the pan several times, not across.
500/thumbs/IMG_1088.jpg
by Frazier85
500/thumbs/mymonte2.jpg
by 85PrimeredMCSS
500/thumbs/Photo0186.jpg
by benen
500/thumbs/Glen.jpg
by PontiCarlo468
500/thumbs/DSC01986.JPG
by msh1987
