#1057715 - 06/11/18 01:11 AM Garage/Shop Cleanout - Motor, wheels, suspension..
AkronAero Offline
AkronAero  Offline
These parts were either taken from or purchased for my 1987 Monte Carlo SS which has 54,000 original miles. Non-original items have less than 2K miles of use (some never used), which is also when the engine was rebuilt. PM me with questions or request for further details or photos. Will consider reasonable offers. May drive your way from time to time?
Engine – All or Parts
Original 1987 305 HO with 54,000 original miles.
500 miles since professional rebuild with new crank, cams, rods, rings and seals.
No EGR.
Includes almost new (less than 2000 miles) the following:
* Holley 4160C 600CFM polished carb (Model 0-80457S; $286 new).
* Edelbrock Performer Intake Manifold (Model 2104; $180 new)
* Mallory Street HEI distributor with coil (Model 8548201C; $160 new)
* Rebuilt alternator
* A/C has new freon type
* Full length headers and if wanted the entire true dual exhaust (pipes and mufflers).
Taken out during restoration and decided to replace with crate 383.
Ready to install - only lacking an oil sensor.
Asking $300 for entire engine or $300 for any/all parts if you want to remove them.
Near Akron Ohio.
Radiator
Three core copper radiator with transmission cooler. All copper; no plastic. Coolant enters in upper left (1-3/8” Driver) and exits to pump on lower right (1-1/2” Passenger). Better than stock, and great for 180+HP but marginal for 500+HP. Approx size is 31”x19”x1-3/4”. Asking $30 + shipping.
PowerMaster Infini-clock - High Torque Mini-starter - 168 tooth, staggered bolt pattern, clockable. Developed erratic meshing on starts. Swapped out starter then found out it was a badly warped flex-plate. Some minor wear shown on the pinion gear. Paid $200(+). Asking $70 + Shipping.
Intermediate Steering Shaft - with New Rag Joint from Mikes Montes. Paid $170. Asking $45 + Shipping.
2” BelTech Drop Spindles with Moog 5660 Springs. Firm ride with lower stance. Paid $250. Asking $90 + Shipping.
9” Dual Diaphragm Vacuum Booster – Used my original booster for 56,000 miles, the last two years with a vacuum pump (big cam) and just swapped out for HydraTech Booster. Asking $50 OBO + Shipping.
My Four original (N-90) 15x7 Wheels – Solid but needing paint. No gouges. Asking $100 OBO - Pick up only.
Refurbished Medium Grey Wheels and Tires - Five (5) Refurbished OE (N-90) Wheels done in medium grey with machined faces. Four of the five have 15x7 BFG T/A 235/60-R15 tires each with 8/32” to 9/32” tread (10/32” when new). The fifth wheel was never mounted. Again, these were used for 2K miles. The wheels were exposed to salt one time (not by me) at a shop where work was being done and they were left unwashed for a few months. They have developed “spider” lines across the machined faces. Painted surfaces are all OK. They can be sanded and resealed. Originally wheels were $150 each (Mike’s Montes) and tires were $160 each. They come with newer hub caps and lug nuts. Asking $500 OBO - Pick up only.
Two Newly Refurbished Silver Wheels – Never mounted and still in the boxes. The same refurbished N90 15x7 wheels with machined faces as above from Mike’s Montes but these are in the original silver. Originally $150 each. Asking $175 + shipping for both.
Three Piece Air Box Top Plate and Extensions – Powder coated black, dry mounted but never used. Covers headlight wiring. Purchased from Mikes Montes at $120. Asking $45 + Shipping.
#1057721 - 06/11/18 07:02 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
How much for air box top plate shipped to zip 96816? Can you send picture to my PM?
#1057723 - 06/11/18 02:23 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: FinallySS]
AkronAero Offline
AkronAero  Offline
Ouch - the minimum billable weight is 9 pounds and the shipping cost is somewhere (depending upon how I pack) around $70-$75.
Glad to try finessing this if you would like.
Good news is that arrives at the same price as new before shipping.....
I will send pictures later today.
#1057813 - 06/17/18 11:46 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
spacemanspif Offline
Swedesboro, NJ
Interested in the spindles if shipping doesn’t beat me up. My zip is 08080 if you can get me an estimate.
-Mike
Killed a few cones too
#1057815 - 06/18/18 01:53 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
AkronAero Offline
AkronAero  Offline
Mike
Spindles alone weigh a bit under 35 lbs and the shipping is $35.
Price for spindles alone is $70, or $105 delivered to you.
Springs weigh about 25 lbs.
Shipping for both is between $60 for two packages or $50 for one, but its heavy.
I would quote Spindles and springs delivered to you at $140.
Thoughts?
PM me if you want a photo.
Moog springs are not as pretty as the higher priced ones.... not powder coated I think so surface is more prone to rust.
#1057826 - 06/18/18 03:12 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
AkronAero Offline
AkronAero  Offline
Air Box Top Plate and Extensions have been SOLD.
#1058170 - 07/09/18 02:27 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
ORANGESS Offline
ORANGESS  Offline
LYKENS PA
any pics of the wheels the full set and the 2 loose silver wheels if still available thanks Tony
1986 ORANGE PEARL MONTE SS sold 8/11/11
1987 SILVER MONTE SS ALL STOCK 14K MILES
1987 GRAND NATIONAL ASTRO ROOF sold
2002 DALE EARNHARDT MONTE CARLO SS
2005 SUPERCHARGED MONTE CARLO SS
#1058184 - 07/10/18 12:34 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
AkronAero Offline
AkronAero  Offline
Tony, PM me your prefered email and I will fire a few pics out tomorrow.
#1058185 - 07/10/18 02:14 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
ORANGESS Offline
ORANGESS  Offline
LYKENS PA
PM SENT THANK YOU
#1058682 - 08/20/18 03:44 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
AkronAero Offline
AkronAero  Offline
Bump.
See anything of interest? Make an offer.
G
#1059159 - 09/21/18 02:50 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
Tipps86 Offline
Tipps86  Offline
bartlett,il
Is the 305 still available?
TiPPS
#1059160 - 09/21/18 02:59 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
AkronAero Offline
AkronAero  Offline
Yes - the shop has the 305 on a pallet and the dual exhaust sitting in storage... Help them find a home????
#1059163 - 09/21/18 04:59 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
345HP87SSAC Offline
345HP87SSAC  Offline
Stanberry, MO
wish you were not so far away. I have a use for all that.
#1059224 - 09/26/18 01:21 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
AkronAero Offline
AkronAero  Offline
Bradshaw - thanks for posting. I tried one time to sell the engine on CL for $750, and got an offer for $600 but was traveling and told the shop that was handling it for me to reject the offer. So I am getting around to it only now. I have given a lot away already to MC guys (UMI front UCA/LCA, the 2" drop spindles and springs, etc) who couldn't afford to buy them... Like me when I was younger. So, what is your project now? You are certainly not going to de-tune your aero???? What's up? Curious!
#1059391 - 10/13/18 09:31 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
AkronAero Offline
AkronAero  Offline
SOLD or donated most everything. What's left? Make offer, esp if you are picking up and saving me the effort of packaging.
Radiator -Three core copper radiator with transmission cooler. All copper; no plastic. Coolant enters in upper left (1-3/8” Driver) and exits to pump on lower right (1-1/2” Passenger). Better than stock, and great for 180+HP but marginal for 500+HP. Approx size is 31”x19”x1-3/4”. Asking $30 + shipping.
Refurbished Medium Grey Wheels and Tires - Five (5) Refurbished OE (N-90) Wheels done in medium grey with machined faces. Four of the five have 15x7 BFG T/A 235/60-R15 tires each with 8/32” to 9/32” tread (10/32” when new). The fifth wheel was never mounted. Again, these were used for 2K miles. The wheels were exposed to salt one time (not by me) at a shop where work was being done and they were left unwashed for a few months. They have developed “spider” lines across some of the machined faces. Painted surfaces are all OK. They can be sanded and resealed. Originally wheels were $150 each (Mike’s Montes) and tires were $160 each. They come with newer hub caps and lug nuts. Asking $500 OBO - Pick up only.
#1059591 - 10/26/18 02:30 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
345HP87SSAC Offline
345HP87SSAC  Offline
Stanberry, MO
was looking for a newer style motor to fix a tired tahoe. did not want to spent alot of money on it and didnt really care about power. Well good for you for getting rid of it all.
#1064219 - 11/21/19 04:08 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
hello..Do you still have the intermediate steering shaft? thanks
#1064439 - 12/14/19 12:56 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Is the rag joint still available
#1064440 - 12/14/19 01:44 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
AkronAero Offline
AkronAero  Offline
ALL GONE
Sorry - Dropped off whatever I had left at Mikes Montes to add to his impressive parts collection.Reach out. Its a good piece and only slightly used.
#1064448 - 12/14/19 06:20 AM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Copy . Thanks
#1064714 - 01/08/20 10:30 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Is the steering shaft still available
#1064716 - 01/08/20 11:19 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
AkronAero Offline
AkronAero  Offline
MA - Mike has it not - good condition - ask him.
#1064986 - 02/02/20 02:48 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
PETER86SS Offline
PETER86SS  Offline
Cleveland, TN
Need an EGR control solenoid - sitting on that factory intake you may still have on a shelf, or on the floor holding a door open - here's a link that should have a picture
https://www.yoyopart.com/oem/13652331/standardmotor-products-vs8.html#application
Thanks for your time, Peter
#1065016 - 02/04/20 07:40 PM Re: Garage/Shop Cleanout - Motor, wheels, suspension.. [Re: AkronAero]
PB86SS/87LS Online beer
PB86SS/87LS  Online Beer
I believe I have several, do you see any in the pictures? I thought some were visible.
500/thumbs/monte_115.jpg
by Savage 88
731/thumbs/headliner_on_table.JPG
by StripedSS
519/thumbs/DSC00025.JPG
by Ted88SS
640/thumbs/inshop.jpg
by BLUE
500/thumbs/DSC000261.JPG
by SSexxymonte
