#1056232 - 03/05/18 05:40 PM Anyone have frame side motor mount laying around?
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
If so, I could use a dimension. Distance from the frame mount surface to centerline of hole for the long thru bolt that connects it to the other bracket.
#1056244 - 03/06/18 01:38 AM Re: Anyone have frame side motor mount laying around? [Re: Tunedss86]
Warriorridge Offline
Petersburg PA
I might, I can check tomorrow when I go out to my shop.
#1056245 - 03/06/18 01:42 AM Re: Anyone have frame side motor mount laying around? [Re: Tunedss86]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Thanks.
#1056250 - 03/06/18 02:28 AM Re: Anyone have frame side motor mount laying around? [Re: Tunedss86]
AkronAero Offline
AkronAero  Offline
In my swap, I used the steel motor mount (frame pad) for the our cars - Moroso part 62630.
The centerline of the tube/bolt appears to be almost exactly 1" off the frame, but I did not mic this (I am however holding one in my hand with a tape measure).
This can be matched with either a steel mount (block mount) like Moroso part 62515, which I originally used, or the interlocking urethane unit from Energy Suspension part 31117 to which I am switching tomorrow (Coincidence? I think not!)
Note that these are the "high and narrow" mounts, spec'ed for Montes and related full sized Chevys, not the "short and wide" design.
If using the above Morosos 62515 the centerline sits 2-9/32" off/below the block.
The Energy Suspension 31117 (use the base plate) centerline will sit 2-3/16" off/below the block.
Don't know how that compares to the OE clamshell or what you may be using on your LS2 if different.
HTH
#1056268 - 03/06/18 08:37 PM Re: Anyone have frame side motor mount laying around? [Re: Tunedss86]
AkronAero Offline
AkronAero  Offline
CORRECTION to my above comment on the mating of the Energy Suspension (motor side) mounts to the Morosos (or other) frame side mounts....
Had to cut the Moroso ears around the bolt hole and tube down to get clearance.
Energy Suspension says they designed their mounts to fit around the OE clamshell mount lower (assuming its mounted without the rubber insert).
I hope that is not confusing.
Back on the ground in a few days and will test this out.
#1056271 - 03/06/18 10:54 PM Re: Anyone have frame side motor mount laying around? [Re: Tunedss86]
Petersburg PA
About 1 inch. The mounts I measured were the old original ones from my car, so the measurement not but 100% precise compared to a fresh one, but it should be close.
500/thumbs/monte_115.jpg
by Savage 88
731/thumbs/headliner_on_table.JPG
by StripedSS
519/thumbs/DSC00025.JPG
by Ted88SS
640/thumbs/inshop.jpg
by BLUE
500/thumbs/DSC000261.JPG
by SSexxymonte
