#1056103 - 02/26/18 06:03 PM Help identifying non-original rear end
JesusCPenney Offline
Fort Worth, TX
Hey folks, I'm hoping someone here is good with axle stamps or knows where I can look up this info. My '85 SS doesn't have the original rear end, it's a non-posi unit that's stamped "9TZ" on the passenger side axle tube.
Any idea what it is? Google doesn't seem to be helping, and I'd like to know what my gear ratio is. I'd also like to figure out if I can convert this to the factory 3.73 posi or if the entire rear end would need to be swapped.
#1056127 - 02/27/18 06:49 PM Re: Help identifying non-original rear end [Re: JesusCPenney]
This is the only g-body axle codes that I've seen posted:
http://www.g-body.org/tnt/diffs/diff-codes.php
I'd be curious if you find out what it is. So your RPO code has G80 to know it was a factory posi rear?
#1056129 - 02/27/18 07:18 PM Re: Help identifying non-original rear end [Re: JesusCPenney]
TZ sounds like you have an open diff with 2.56 gears. C is Buffalo assembly plant.
The other numbers are the date of manufacture on the second shift.
The 9 is "1979", just a guess.
But one of the charts says TZ is a code used in 1977.
http://rustynutscarclub.com/novaaxlecode.htm
http://novaresource.org/axle.htm
#1056132 - 02/27/18 09:45 PM Re: Help identifying non-original rear end [Re: JesusCPenney]
If it has metric or standard studs, that might help figure out if it's a 1978-1981 rear as well. My SS had a rear from that range when I bought it, standard studs, found out the hard way with lugs/wheel coming loose.
#1056357 - 03/13/18 02:09 AM Re: Help identifying non-original rear end [Re: JesusCPenney]
Fort Worth, TX
Thanks folks. Someone with a copy of some GM literature showed me a chart saying TZ was 3.73 Posi but I'm not 100% sure. If it is a Positrac unit, then the limited slip components have failed for sure. It does have the metric studs, same ones as the front wheels.
#1056362 - 03/13/18 11:48 AM Re: Help identifying non-original rear end [Re: JesusCPenney]
88ss408 Offline
88ss408  Offline
miramichi, NB
The studs are easy to change. It could still be a older rear with newer studs. But easyest way to tell is to pop the cover. The stampings is on the ring gear for the ratio and you will see the differential. All it will cost is gear oil and gasket.
1988 monte carlo ss 408 sbc
1984 monte carlo cs 400 sbc
#1056521 - 03/21/18 01:50 PM Re: Help identifying non-original rear end [Re: 88ss408]
You can also turn the yoke, count the number of turns to revolve the axle(s) once. 3 3/4 turns and you have a 3.73, both axles turn in the same direction and you have a posi. The yoke will only turn 2 1/2 times with 2.56 gears.
#1056536 - 03/21/18 06:08 PM Re: Help identifying non-original rear end [Re: upflying]
Originally Posted by upflying
[quote=88ss408]The studs are easy to change. It could still be a older rear with newer studs. But easyest way to tell is to pop the cover. The stampings is on the ring gear for the ratio and you will see the differential. All it will cost is gear oil and gasket.
Yes do it this way, no questions after that.
#1056541 - 03/21/18 07:57 PM Re: Help identifying non-original rear end [Re: JesusCPenney]
Also pop the cover, it's due for a fluid change for sure and inspect the splined spider gears for lateral play. that's how i lost an axle at 70mph... an old worn out posi unit...
#1056607 - 03/24/18 11:07 PM Re: Help identifying non-original rear end [Re: Travis Jones]
84LS1T56SS Offline
84LS1T56SS  Offline
Central, Arkansas
I'll bet that was exciting.
by Monster
523/thumbs/DSC_0656.jpg
by Dad's SS
1164/thumbs/IMGP6649small.jpg
by Witman69
523/thumbs/DSC_0633.jpg
