#1055139 - 01/04/18 05:36 PM LSx motor mount question
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Has anyone moved the frame mount on (specifically) the passenger side back & found a motor side mount to work with it? I need some extra room for a low mount AC mount.
#1055150 - 01/05/18 12:49 AM Re: LSx motor mount question [Re: Tunedss86]
spacemanspif Offline
Swedesboro, NJ
I've seen people notch the frame to clear the AC. Maybe a set of dirty dingo adjustable motor mounts would work and enable the driver's side to sit one way and the passenger side the other. Essentially you are looking forn 1 regular mount adapter and 1 set back style. At the end of the day is the work worth the effort vs the cost of a Holley high mount AC bracket?
-Mike
Killed a few cones too
#1055153 - 01/05/18 01:11 AM Re: LSx motor mount question [Re: Tunedss86]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Can't use a hugh mount AC with a LSA supercharger & OEM belt setup. I know there are other accessory drives, but $$
#1055156 - 01/05/18 02:40 AM Re: LSx motor mount question [Re: Tunedss86]
Swedesboro, NJ
A blower is a good reason lol. Have you measured for how far you want to move the mount? We dealing with an inch, or 2 or 7?
-Mike
#1055163 - 01/05/18 09:44 AM Re: LSx motor mount question [Re: Tunedss86]
jmireles Offline
jmireles  Offline
El Paso, Tx
How about an AC bracket from Kwik Performance? Does that leave you in the same boat as with the Holley set up?
in '08. 3K
#1055164 - 01/05/18 02:22 PM Re: LSx motor mount question [Re: Tunedss86]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Still will have to notch the crossmember & any notch will also interfere with frame side motor mount. So whatever I do I will need to push that back.
Edit, unless you are referring to a high mount from kwick, I need to mount it low.
#1055187 - 01/06/18 03:18 PM Re: LSx motor mount question [Re: Tunedss86]
I think you should be able to move the frame mount back to the V6 mount holes and use a slotted style "forward setback" adapter plate to buy some room.
#1055188 - 01/06/18 04:41 PM Re: LSx motor mount question [Re: Tunedss86]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
That's what I was thinking about doing. Doing so will then probably interfere with the headers.
#1055189 - 01/06/18 04:50 PM Re: LSx motor mount question [Re: Tunedss86]
Swedesboro, NJ
Not necessarily, if you use headers that clear with the forward mounts, there should be plenty of room to clear the setback mount position with the frame notch. I think most headers will clear either mount design because there is so many options it would be silly to make 2 different headers just for ~1" of difference between designs.
-Mike
#1055203 - 01/08/18 02:36 PM Re: LSx motor mount question [Re: Tunedss86]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Is there a frame side pad that will we can use that isn't so wide as stock Monte?
#1055204 - 01/08/18 03:24 PM Re: LSx motor mount question [Re: Tunedss86]
MC96 Offline
MC96  Offline
St. Johns MI
https://www.speedwaymotors.com/Speedway-SBC-BBC-Chevy-V8-Solid-Steel-Frame-Mounts,6990.html
86 SS
In progress
#1055346 - 01/15/18 04:18 PM Re: LSx motor mount question [Re: Tunedss86]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Decided I will make my own.
#1055362 - 01/16/18 03:26 AM Re: LSx motor mount question [Re: Tunedss86]
Looks good! Cnc plasma?
#1055366 - 01/16/18 11:47 AM Re: LSx motor mount question [Re: Tunedss86]
Swedesboro, NJ
Looks like the Holley mounts
Maybe copy their use of counter sunk bolt heads for low profile and good looks
https://www.summitracing.com/parts/...jrLTc2AIVV7bACh2M8ADAEAQYCSABEgK8MPD_BwE
-Mike
#1055367 - 01/16/18 01:37 PM Re: LSx motor mount question [Re: Tunedss86]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Found someonw to laser cut them for me.
Looks like holley? Hmmm.
Dunno that countersinking them will buy me anything. Unless it interferes with the frame bracket.
500/thumbs/monte38.jpg
by NYLilaFan
500/thumbs/DSCF0008_10_car5.jpg
by 06mcss
500/thumbs/new_pics_007.jpg
by Kelley
500/thumbs/carlo5.jpg
by rj
500/thumbs/DSCF9662-jpg.jpg
by f14dmechanic
