#1054670 - 12/03/17 02:02 AM Purchased a possible 86 SS 200 4R
NascarT/A Offline
NascarT/A  Offline
Macomb, MI
Hello I am new to the forum. Joined to get information on a 200 4R transmission that was in an 86 Monte SS. I am trying to figure out what this is. There is no ID plate and the trans is painted black. So far this is what I found. It has a green driver speedo gear. I think it is 10 tooth gear with a brown 30 tooth driven gear. The TC was painted grey and had a 5 with part of a circle on the shell between every blade pockets. Does this sound like it is a SS trans. Thanks in advance.
#1054678 - 12/03/17 07:34 AM Re: Purchased a possible 86 SS 200 4R [Re: NascarT/A]
TerMonteNator1986SS Offline
Edmonton, Alta
I read somewhere on this site that if you take pan off, that the valve body has either pink or purple paint on it (unless its worn off), and should also have a code on it. HTH.
#1054681 - 12/03/17 09:28 AM Re: Purchased a possible 86 SS 200 4R [Re: NascarT/A]
The SS had a D5 stamped into the torque converter.
#1054684 - 12/03/17 03:13 PM Re: Purchased a possible 86 SS 200 4R [Re: NascarT/A]
If the tag is gone and repainted, good chance it was rebuilt and who knows what parts could of been changed if so. Sounds like it has the D5 convertor though. I thought the brown gear is for a different number/ratio, I believe I have one and that it is for a 3.08 rear(26 tooth?) but that is off my memory. IIRC a blue 30 tooth was for 3.73's. There must be a few sites out there that break this down.
#1054689 - 12/03/17 06:15 PM Re: Purchased a possible 86 SS 200 4R [Re: PB86SS/87LS]
NascarT/A Offline
NascarT/A  Offline
Macomb, MI
Hello and thanks for all the replies. The speedo gear was was brown and it had 30 stamped in it. I also counted the teeth three times and came up with 29 once and 30 twice. This gear was brown with a metal shaft.
Lee
#1054690 - 12/03/17 11:14 PM Re: Purchased a possible 86 SS 200 4R [Re: NascarT/A]
zelm86ss Offline
zelm86ss  Offline
Bremen,In
My valve body had the code (cz) on it. Take the pan off and see if there's a code on it.
#1054695 - 12/04/17 03:56 PM Re: Purchased a possible 86 SS 200 4R [Re: zelm86ss]
kevins88ss Offline
kevins88ss  Offline
Southern Maine
Here's a couple of pics of the valve body from my CZF code 200-4R. (Ignore the red arrows, they were for an issue I was having)
#1054701 - 12/04/17 08:03 PM Re: Purchased a possible 86 SS 200 4R [Re: zelm86ss]
Where in the pictures?
From what I understand the letters are on the side of the valve body.
#1054702 - 12/04/17 08:39 PM Re: Purchased a possible 86 SS 200 4R [Re: NascarT/A]
zelm86ss Offline
zelm86ss  Offline
Bremen,In
Mine was in large white letters right on the side of the valve body casting. I don't have a pic, but you can't miss it if it's there.
#1054709 - 12/06/17 12:28 AM Re: Purchased a possible 86 SS 200 4R [Re: zelm86ss]
NascarT/A Offline
NascarT/A  Offline
Macomb, MI
I think the next step is to pull off the pan. I am worried what I will find. The guy I bought from said there was a a coloured stripe in the valvebody. I have to confirm this. He also said it would shift at 5200 RPM. Like PB86SS said, "If the tag is gone and repainted, good chance it was rebuilt and who knows what parts could of been changed"
#1054737 - 12/08/17 10:06 PM Re: Purchased a possible 86 SS 200 4R [Re: NascarT/A]
Yeah pull the pan and see if there is a letter code. The other thing is if it shifts good why worry? Are you using a "stock" 305? My gut feeling, being it looks like a D5 converter you have an SS trans that was rebuilt.
#1054920 - 12/20/17 07:09 PM Re: Purchased a possible 86 SS 200 4R [Re: NascarT/A]
guitars Offline
guitars  Offline
Toronto, Canada
Yellow painted letters on the valve body, driver side side near the shift detent.
852/thumbs/1981_mont_carlo.jpg
by PoorBoysRacing
500/thumbs/Monte2_mid.JPG
by woolf
500/thumbs/06-08-07_1245.jpg
by ETHIOSLS
500/thumbs/parts2.jpg
by go3and8
500/thumbs/RR.jpg
by Greg Talbott
