#1052800 - 08/07/17 12:18 PM strange underhood plug 84 monte
markg Offline
markg  Offline
nj
i don't have a pic of it but its a black rubber plug about 3/4 inch diameter.
it has 2 male spade connectors in it.one is vertical and the other is horizontal.
its kinda greasy so I don't think it goes on the top of the engine.
the car originally had a 3.8 v6 and this plug is on the pass side.
any ideas?
#1052813 - 08/07/17 04:47 PM Re: strange underhood plug 84 monte [Re: markg]
speeddemon Offline
speeddemon  Offline
NW Iowa
Sounds like it had an engine block heater at one time.
Jeff J
#1052814 - 08/07/17 06:36 PM Re: strange underhood plug 84 monte [Re: markg]
markg Offline
markg  Offline
nj
car was bought and resided in florida for all of its life before I got it .
could it have possibly gone to the trans that I scrapped with the engine?
the wire looks long enough to go there.
it was one of those pre 200r transmissions
#1052825 - 08/08/17 11:17 AM Re: strange underhood plug 84 monte [Re: markg]
88ss408 Offline
88ss408  Offline
miramichi, NB
What color are the wires? Sounds like it's the wires for the lockup torque.
1988 monte carlo ss 408 sbc
1984 monte carlo cs 400 sbc
#1052921 - 08/14/17 01:46 PM Re: strange underhood plug 84 monte [Re: 88ss408]
markg Offline
markg  Offline
nj
[img]https://gbodyforum.com/media/plug-2.2160/full[/img]
here it is.any ideas?
#1052922 - 08/14/17 03:32 PM Re: strange underhood plug 84 monte [Re: markg]
88ss408 Offline
88ss408  Offline
miramichi, NB
Yeah. That looks like the wires that powers the AC compresser. There's 2 switches. I took all of them off my car last year. I think one goes to the power steering pressure line. I removed them I wired the direct.
#1052923 - 08/14/17 05:22 PM Re: strange underhood plug 84 monte [Re: markg]
markg Offline
markg  Offline
nj
there is no plug on the ps pump hose.(I have one on my 86)
if it doesn't go there where is the other spot you mention?
my compressor has a plug on it with 2 wires but it is narrow and side by side.
#1052924 - 08/14/17 05:37 PM Re: strange underhood plug 84 monte [Re: markg]
It looks like it's the plug that goes to the pressure switch on the ac accumulator.
Look here and go down to post #6.
https://gbodyforum.com/threads/ac-clutch-not-engaging.29849/
#1052925 - 08/14/17 05:42 PM Re: strange underhood plug 84 monte [Re: markg]
markg Offline
markg  Offline
nj
thanks....I already have that plug on the accumulator.
#1052926 - 08/14/17 07:17 PM Re: strange underhood plug 84 monte [Re: markg]
OK I stand corrected. Went over to where my car is stored and saw that the plug for the pressure accumulator pressure switch is 3 wires.
My car was a V6 and TH200C trans.
I have the same plug as what you have with the label still on it when I changed out the trans to a 200R4.
It say's "pressure switch R/S of trans"
88ss408 suggested it was for lock up and I would agree with that..
The rubber boot is about 1/2" in diameter and the two wires have old oil on them and the color of them looks to be dark blue or green.
I pulled the wires up so they are at the firewall near the distributor.
I would show a picture but I have Photobucket and can't post it on the forum.
#1052928 - 08/14/17 07:33 PM Re: strange underhood plug 84 monte [Re: markg]
markg Offline
markg  Offline
nj
wow....thanks Richie!
im sure that's it!
#1052931 - 08/14/17 09:40 PM Re: strange underhood plug 84 monte [Re: markg]
88ss408 Offline
88ss408  Offline
miramichi, NB
Yeah the ones for the Trans are blue and green.
#1052932 - 08/14/17 09:45 PM Re: strange underhood plug 84 monte [Re: markg]
88ss408 Offline
88ss408  Offline
miramichi, NB
The plug your holding in that pic seems to have 2 dark green wires. That's why I mentioned the AC clutch wires.
and I remember taking off 2 of them switches one was at the sterring hose. And the other one I can't remember now.
#1053561 - 09/23/17 11:41 PM Re: strange underhood plug 84 monte [Re: markg]
markg Offline
markg  Offline
nj
ok almost done.
this is the big clump of wires that go into the pass side firewall thru the inner fender.im pretty sure I can clip all of these and I wont ever be going back to the computer.the 2 wires in my hand im not sure if I should clip though.one is a big ground wire(do I need it hooked up)?
and the other is a 4 prong plug that im not sure where it goes either.
weve already determined that its not the plug for the trans.
any ideas?
alsi I need to run a hot to my choke.
a couple of these wires seem hot when the key is on.is it a bad idea to run one of these to the hot wire on the choke?
thanks again for all of your help!
#1053562 - 09/23/17 11:42 PM Re: strange underhood plug 84 monte [Re: markg]
markg Offline
markg  Offline
nj
#1053568 - 09/24/17 07:07 AM Re: strange underhood plug 84 monte [Re: markg]
Don't cut the harness. A good uncut harness is worth a $100 or more. Also the open air cleaner is sucking in hot air and causes turbulence into the carb.
#1053569 - 09/24/17 12:53 PM Re: strange underhood plug 84 monte [Re: markg]
88ss408 Offline
88ss408  Offline
miramichi, NB
Everything coming from the passenger side bulkhead can be taken off.
Yes the 12v + can be taken from any keyed source. Just don't take it from the distributor wire like some do.
#1053708 - 09/30/17 06:02 AM Re: strange underhood plug 84 monte [Re: markg]
1montess85 Offline
1montess85  Offline
Rineyville, KY
Been a long time but I think that 4 prong is for the smog pump. It's on the pass. side right? Oh and I agree with the other guys. Don't cut the harness. They're not making them anymore, so it's got some value. Pull the kickpanel, undo 3 plugs, and push it all through the firewall. I made a plate out of some flashing to cover the hole. Put a couple "ears" on it and lay a bead of sealer on it. Run a couple sheet metal screws through the existing holes and you'll be all set.
1985 SS
White Lightnin'
Saved from the junkyard. Restored 2006. Recent LT4 HOT cam/Vortec head 350 install.
500/thumbs/monte_0061.JPG
by bootlegger
500/thumbs/1985_monte.JPG
by Hostile
536/thumbs/51.jpg
by ssmnt408
500/thumbs/SS5.JPG
by IowanSS
857/thumbs/Ram_Air_small.jpg
by 86SSmonte350
