#1052521 - 07/23/17 02:17 AM Need Engine Swap help :(
Cheford Offline
Cheford  Offline
Ottawa, Ontario
So i have a question for you guys.....How much work would be involved in installing a Buick 455ci?
I have a 1987 Monte Carlo SS 305ci right now with a mild 400hp 350ci.
#1052531 - 07/23/17 06:31 PM Re: Need Engine Swap help :( [Re: Cheford]
TooSlow406 Offline
TooSlow406  Offline
Dickinson, TX
If you're keeping all the CCC stuff, then quite a bit. If you're getting rid of all that, then the swap is pretty simple- an engine is an engine. A Little less room with a "big block".
I wouldnt do it unless that 455 is for free. I'd rather spend the money and go 454 or 502 bbc.
#1052532 - 07/23/17 07:22 PM Re: Need Engine Swap help :( [Re: Cheford]
Cheford Offline
Cheford  Offline
Ottawa, Ontario
The engine is built and 1500$, the 350ci I have now is a non cc carb, cam, ditrubutor. Not sure what else the comp controls but I've eliminated those 3 things
#1052533 - 07/23/17 08:18 PM Re: Need Engine Swap help :( [Re: Cheford]
If you have AC, the 455 might and probably will mean removal of the evaporator case. Other tight fit questions will be exhaust routing, brake booster and steering shaft.
A BOP bellhousing or adaptor on the trans might be needed too. Not a common swap so you might be fabricating stuff instead of buying things from Summit or Jegs.
If you make it fit, the Buick will be a low rpm torque monster.
#1052534 - 07/23/17 11:45 PM Re: Need Engine Swap help :( [Re: Cheford]
speeddemon Offline
speeddemon  Offline
NW Iowa
You can use common 3.8 frame mounts from a regal or cutlass, adapter for the bellhousing or a different transmission. The A/C box will fit just as tight as a BBC. If you use the stock power steering pump from the Buick you will need the line adaptors for the high pressure line, A body headers will fit a monte with some slight clearancing.
This is a pretty common swap into mid 80's regals, very little difference to a monte.
Jeff J
#1052535 - 07/23/17 11:58 PM Re: Need Engine Swap help :( [Re: Cheford]
tedgley Offline
tedgley  Offline
Covington, KY
The 455 should bolt straight to the 200-4R trans...and kill it in short order if you like the gas pedal and you don't change some of the guts inside.
#1052625 - 07/29/17 02:08 AM Re: Need Engine Swap help :( [Re: Cheford]
The 200-4r needs no adapter!
500/thumbs/monte_0061.JPG
by bootlegger
500/thumbs/1985_monte.JPG
by Hostile
536/thumbs/51.jpg
by ssmnt408
500/thumbs/SS5.JPG
by IowanSS
857/thumbs/Ram_Air_small.jpg
by 86SSmonte350
